Originally Posted by bigbird
ya know, you may be having problems with your alternator. if an alternator is not runnin good then the car will draw more power from the battery and thus ware it out faster. every replace yours?
Exactly.
The battery is really not quite as important as everyone believes it to be. The battery (in essence) has two main duties:
1) Starting
2) Acting as a large capacitor when momentary/instaneous high demands are put on the system.
Other than that the electrical system is regenerative by means of the alternator. When a high (constant, not instaneous) demand comes in, the battery is first to respond, then the alternator steps up its output to the system (and the battery, so anything lost is recovered). When the power is required without 'waiting' on the alternator, the battery is relied on to have the amps on hand to do the task necessary.
While the car is running, you can remove the positive lines from either the alternator or the battery and the car will keep running. Now, if you pull the line off the battery and the car dies immediately, it means your alternator is dead. Vice-Versa is also true.
So, where you'll see a difference is if the Alternator is pushing out more current (amps) to the system. Things like windows, fans, inverters, and some other devices are continuous high load devices (meaning they'll rely more on the alternator kicking out power than the battery) while other things such as Amplifiers are instantaneous devices, meaning that the battery has to have the amps on hand to drive it, it can't wait on the alternator to respond. Starting relies on the battery simply because the alternator's not runnign yet, and that starter solenoid and motor can pull an amazing amount of current (due to it's gearing).
So, if the battery made a big difference I'd either look at maintenance or replacement (upgrade?) of the alternator.
