0401 EGR insufficient flow help!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2008, 11:27 PM   #1 (permalink)
View steven88's Photo Gallery
I have a 95 toyota camry v6 with the 0401 EGR code. Now from what I researched on the forums, it can be 3 different things...VSV, EGR valve, Vacuum Modulator
Is there a way to clean any of these parts to get rid of the CEL? I notice everytime I clear it with a scan tool, the code doesn't come back until 3 days later....so I am thinking one of these parts is just a little dirty...Does anyone have instructions to clean the vacuum modulator or EGR valve?
I just want to see if there are any solutions to fixing the problem before I go out and buy new parts...thanks in advanced!
steven88 is offline   Reply With Quote
Old 03-28-2008, 01:29 PM   #2 (permalink)
View hooRAH's Photo Gallery
Unbolt the EGR and clean it out with carb cleaner.
You will need to vacuum test the other two parts. Its pretty easy. Or, you could open up the EGR modulator and see if the seal is cracked. Its usually the EGR modulator.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 03-28-2008, 02:00 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
It takes a certain number of miles under varying conditions before a CEL code comes up again. It may be taking you about three days for this to occur.
Like HooRAH suggested, pull the EGR & clean it (plenty of posts on how to). You may end up having to chip some of the carbon out with a small screw driver. Be careful not to damage the valve. Also check the vacuum hoses going to the modulator. Sometimes the lower one gets clogged up.
Kep
Old 03-28-2008, 02:25 PM   #4 (permalink)
Kep
what would be the best way to clean the hoses? is brake cleaner too strong?
also is it possible to clean the modulator? or once it is out, it's out?
Old 04-01-2008, 09:19 PM   #5 (permalink)
bump
Old 04-01-2008, 10:01 PM   #6 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
have that code for about a yea rnow i've done everything possible and im chanign the VSV adn not teh one at the bottom of the block the one near the canister hopefully its help with the code, i'll also re clean my modulator and see wat else my be wrong
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 04-02-2008, 01:11 PM   #7 (permalink)
not your average bear
View justchillinjefe's Photo Gallery
I cleaned out the EGR, tested the VSV and modulator and the light went away for a day or two.
It came back, i ignored it for a month or so, then I started using 89 octane.
Shortly after I started using the 89, the light went away.
My 2 cents
justchillinjefe is offline   Reply With Quote
Old 04-02-2008, 02:21 PM   #8 (permalink)
Kep
Kep's Avatar
stephen88,
Sorry, I didn't see your question. I used a small phillips screwdriver to clean out my hose. The hose was about 2" long and I used the phillips like a drill bit. Twisted, removed, shook out the dust, did it again, etc...
Kep
Old 04-03-2008, 08:50 AM   #9 (permalink)
Dude Wheres My Car?
nukem678's Avatar
View nukem678's Photo Gallery
I had the same problem. Egr was like new, i changed the modulator and nothing. Then i finally got a vsv and vouala. It fixed the problem, so if the egr is clean most likely its the vsv, not the hoses. My vsv wount even click when power was applied, it was dead. It was just a pia to change.
I lost my Camry in a parking lot once, Now it will never happen again
nukem678 is offline   Reply With Quote
Old 04-03-2008, 10:20 PM   #10 (permalink)
so the VSV is hard to change? I thought it was under the engine cover?
Old 04-03-2008, 10:29 PM   #11 (permalink)
Dude Wheres My Car?
nukem678's Avatar
On an i4 its a PIA but your v6 youll be ok.
Old 04-03-2008, 10:43 PM   #12 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
My 2 cents
thats a result of using lower then standerd gas on the V6. toyota recommends 89 or higher on the 1mz.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-04-2008, 01:11 AM   #13 (permalink)
Yes, but the car had been running on 87 for 10+ years with no code.
