2001 Evap Emissions in FSM stills show early non-intrusive type
I have a 2001 Solara on which I am battling it out with the Evap system. When I downloaded the FSM from the Camry Stuff website I found in the 1997-2001 Factory Service Manual that the only schematic shown in the Evap Emission section is still only for the early non-intrusive type. Does anyone know if any of the newer Camrys use the same late intrusive-type system as the 2001? I believe that 2001 was the first year for the late intrusive-type but it is NOT the Echo.
The intrusive type has a two-way Pressure Switching VSV instead of a three-way and also has a VSV for Canister Closed Valve mounted to the air cleaner box that the earlier systems don't use at all. Also the Vapor Pressure Sensor is piped directly to the fuel tank instead of being switched by the three-way VSV.
Thanks,
Gary
