I had a very similar problem with my V6 after I changed the spark plugs. I had to remove the plenum gasket to get to them and everyone said it was a vacuum leak. I never found the vac leak. Tons of codes started popping up through the CEL.
Eventually I resealed the plenum gasket and added a new gasket which I did not do before. I also adjusted the TPS (Throttle Position Sensor) along with the idle screw just below the (hook that you pull back to rev the engine....sorry I don't know the name of it). Play around with those 2 things and you may find that in your interest. Good Luck.
Took me WEEKS to get mine straight. My idle was around 2100 and at 1500 in drive. Now its at idle in park is around 850rpms.
Originally Posted by cashrock
I changed the head gasket and timing belt on a 4 cyl. '96 camry. When I start it, it's very loud like I have an exhaust leak. But my real concern is it's idle speed--3000+ rpm. I've checked for hoses and wires, sprayed carburetor cleaner all over the hoses looking for a vacuum leak, tried adjusting the timing belt this way and that--nothing. The accelerator is not stuck in any way.
My nerd intuition tells me that the exhaust problem is independent of the idle speed issue, but can someone tell me for sure whether one might affect the other?
Otherwise, any ideas on what might make it idle that fast would be most welcome.
