Integration Relay blues or something else??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2008, 02:08 PM   #1 (permalink)
View loghead's Photo Gallery
Hi there,
I could use a little advice (maybe a schematic too).
Here's situation for my 99 Camry LE (4cylinder)
1) dome light is out (but bulb tests good)
2)one headlight works intermittently (but hi-beams are fine)
3) power locks are dead
4) digital clock is dead
5) Dealer alarm RS3000 is dead
My best thought is a bad integration relay (or maybe a bad ECU for the alarm?) I would appreciate any advice or schematics (all I have is the Haynes manual which doesn't give any good troubleshooting tips for the integration relay. thx for helping a newbie...
loghead is offline   Reply With Quote
Old 03-31-2008, 01:54 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Did these all go out at once?
Kep
Old 03-31-2008, 05:49 PM   #3 (permalink)
nope, it's more like a dribble
First the lights went out. Changed the dome light, then the clock went out.
Headlight comes and goes, hibeams are always fine. Then alarm system completely died and power locks too. Actually, the power locks now work again, but only with the key in accessory position... any suggestions for troubleshooting. Am I looking for a loose ground wire, bad alarm ECU or the integration relay (a.k.a. power distribution relay)
Old 04-01-2008, 11:09 AM   #4 (permalink)
Kep
Kep's Avatar
I am afraid that I am at a loss. The door lock thing is weird. Do all of the locks open when you use the key from the outside passenger door?
If it were one thing (a loose ground for instance) then they would all be affected at one time. I think you are looking at several different problems. Alarm systems can be devious but since the car starts I think that means it's OK.
Kep
Old 04-02-2008, 06:01 AM   #5 (permalink)
it is weird. I think you may be right, perhaps there are multiple troubles here.
A few more observations;
1) using the key from the outside does not open all the locks. The ONLY way to get power locks to work is to have the key in the ignition
2) Digital clock does not light up (unless you press the set hour or minute button)!
3) Alarm system died sometime after clock went out
4) here is the order things went down: headlights, dome light, clock and the last to go was alarm system. this wasn't a lightning hit. And periodically the headlight starts working again.
maybe this isn't a job for DIY-er. I'm pretty handy at fixing one component at a time, but this might be a little too much heavy lifting. I still want to check some voltages on the integration relay (aka Power Distribution Relay) though
Thanks for thinking about my troubles, now as long as I don't get pulled over for driving around with an intermittent headlight...
