95 Camry Brake Fluid Problem
I have a 95 Camry, V6, LE, with ABS. The ABS annunciator has been illuminated for the past 2 years, I just ignore it. But, in the past year, I have had the left front caliper hang up. So, I replaced both front calipers along with the rotors. On this last change, I replaced the LF brake hose. Then proceeded to bleed the lines. The RF came up quickly, within a couple presses of the brake pedal. The LF took much longer and was not normal. I can get the brake to come up, but there is not a normal flow of brake fluid. If I continue to bleed the LF the flow of fluid decreases. I do have brakes but am still concerned about the fluid flow in the LF. Any ideas. Thanks
