Door open lamp - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2008, 11:14 AM   #1 (permalink)
View markusgm1's Photo Gallery
Door open lamp
Have a 94 Camry..When the car is started the door open lamp on the dash is off. When you step on the brake, the lamp comes on and stays on till the car is shut off.
Any ideas????
Thanks
markusgm1 is offline   Reply With Quote
Old 04-01-2008, 02:39 PM   #2 (permalink)
View Bear95's Photo Gallery
Any ideas????
Thanks
I believe that you are looking at the burned- out- bulb indicator. Check your rear lights.
Bear95
Bear95 is offline   Reply With Quote
Old 04-02-2008, 07:18 AM   #3 (permalink)
Bear95,
You are correct it is the tail lamp indicator. But, all lamps work when you hit the brake.....
Old 04-02-2008, 07:29 AM   #4 (permalink)
camrtm3's Avatar
Gameroom cash: $102305
View camrtm3's Photo Gallery
Check your center tail light. I had this problem, found other bulbs that were burned out in the process and the other lights were working. Took my dad to find that the center tail light was out...
camrtm3 is offline   Reply With Quote
Old 04-02-2008, 09:10 AM   #5 (permalink)
Bear95,
Yes check ALL the lights. If this is not the problem, then it could be the sensor relay in the trunk.
Bear95
