wierd alignment question
'98 V6 automatic
Just had the front struts, bearings, mount replaced
Just had new standard (205/65r15) put on the oem rims
Just had a 4 wheel alignment
Car rides great!
BUT.... it will pull to the left.... then if I crank the wheel to the limit left.... it will start to pull to the right if I crank it to the limit right...
It is really hard to try and test this all out... because I live in a mountain community... so straight roads are hard to come by..... (the car may self-align after a bit.... But again it is really hard to tell because I really can't go straight for very long) But it definitely does pull....
I have noticed that the drivers side front tire will rub when cranked to the limit left
I have only owned the car for 2 weeks.... and it has 86,000 miles
According to the previous (orig owner) the Rack & pinion was replaced 8.06 at 70,000 miles...
Power steering looks fine.... no leaks, fluid looks fine and is at the correct level.
Any Ideas where I should look 1st???
Thanks
Is the sky the limit ?
1998 Camry XLE V6
2002 Tundra SR5 4x4
