Running Lights Die Please Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2008, 06:37 PM   #1 (permalink)
View kei_kusanagi's Photo Gallery
i bought two led light bulbs for the front corner lights. installed it work for about a couple minutes. Now the running lights went out, even with the OEM bulbs.
Check all fuse, they all are ok.
Replaced the Flasher with a known good one and it's still no good.
Thinking about testing the Turn signal switch but no manual.
I used a volt meter to measure power from the socket, with the running light switch turn on, and there is no 12volt present. ONLY .02 voltage
Where does this green/red wire connected to?
please help any info, wiring diagram, or site. I can check out would be appreciated.
kei_kusanagi is offline   Reply With Quote
Old 04-07-2008, 01:52 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
what green/red wire?
you shorted something, there goes your weekend.
^ and leaving it that way!
