2.2 idle surging - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2008, 11:45 PM   #1 (permalink)
View nschu83's Photo Gallery
3rd Generation 2.2 idle surging
Hey all, I need some help. My 92 2.2 camry has a surging idle as soon as it starts up whether hot or cold and does not stop at all. It started as a high idle and now it started reving from 1200 to 2500 at frequency of maybe 40 Hz. when the car is in gear it idles around 1100 and will surge while traveling around 30. Any ideas or similiar problems?? thank you all for taking a look
nschu83 is offline   Reply With Quote
Old 04-07-2008, 10:54 AM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
How long has it been since you cleaned the throttle body? There are several sensors that might cause this but I think my first step would be to clean the throtle body. If it is dirty then you may want to go ahead and clean the IAC valve and the EGR system. Let us know if this helps or not.
Kep
Old 04-07-2008, 01:27 PM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
cracked vacume line. ebay a set of new fancy hoses.
^ and leaving it that way!
Old 04-07-2008, 01:54 PM   #4 (permalink)
3rd Generation
OK those seem easy enough as per the other posts in the forum. Most people inferred that a hestitant idle would be caused by the dirty TB but its worth shot. Thanks guys and to anyone else with a response!
Old 12-20-2008, 09:55 PM   #5 (permalink)
well took it in to the shop, they claimed it needed a new sensor IAC? didnt fix it and then had a intake gasket leak. Problem solved
