Camry Clicking noise from fuse box in engine ?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2008, 06:17 PM   #1 (permalink)
GoldenAgeCamry
View Purplehaza1987's Photo Gallery
4th Generation Camry Clicking noise from fuse box in engine ??
Their is no power in my car at all i cant even crank the engine i tries jumpstarting it nothing worked also a click like a blinker or hazard light click is coming from the fuse box area i removed the brown relay and the noise stopped and replaced it with another one but it didnt work could it be my battery i do not belive its loose or some sort of electrical fuse thanks..
Purplehaza1987 is offline   Reply With Quote
Old 04-08-2008, 08:54 PM   #2 (permalink)
toyocam99's Avatar
Gameroom cash: $114835
View toyocam99's Photo Gallery
Usually clicking noises are associated with a bad starter.
toyocam99 is offline   Reply With Quote
Old 04-08-2008, 10:55 PM   #3 (permalink)
Proud Toyota Owner
CamryWilly's Avatar
View CamryWilly's Photo Gallery
the clicking is usually the starter solenoid
CamryWilly is offline   Reply With Quote
Old 04-09-2008, 01:15 PM   #4 (permalink)
i go both ways-mac and PC
ghettosled's Avatar
Gameroom cash: $128595
try smacking the starter with a hammer. sounds like there is a bad contact spot and the part that bumps the starter to a new spot isnt working. you have to give it a decent whack as someone turns the key, but dont hit it hard enough to break the case.
Old 04-09-2008, 04:08 PM   #5 (permalink)
Kisuke in rain
Mazeraski's Avatar
View Mazeraski's Photo Gallery
+1
However, this is a temporary solution (thought I would clarify). If you can, get the starter tested (if it will start eventually) to determine for sure if it is the starter thats bad. From the description, it sounds like it is. Keep us updated
1992 Toyota Camry LE 5SFE 4 cyl. 2.2L
A.K.A. "Ron Burgundy"
198,000 mi. (as of February 9th, 2010) and counting
Mazeraski is offline   Reply With Quote
