In my 95 I4 when the key is in the on position but the engine is off the shifter does not move. It is also stuck in park. Somehow it knows that the engine is running before it lets you shift.
Get to the basics. Is your timing belt broken? (easy check, remove the distributor cap and have someone crank the engine while you look. If the rotor doesn't move then the TB is broken.) Are you getting spark? (pull a plug and ground it. Crank the engine and you should see a nice blue spark) Are you getting fuel? (while you have the plug out smell the cylinder after you crank it. Or, when all the plugs are back in, spray a little starter fluid in the air filter. If the engine tries to start then you have a fuel problem.)
Let us know...
Kep
PS- my 95 has an OBDI port. I don't believe that they make a scanner for the OBDIs. You just jump the proper contacts and read the flashes.
