installind a double DIN stereo in Gen 4 Camry w/ JBL audio package - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2008, 12:17 PM   #1 (permalink)
Jayhawk85's Avatar
View Jayhawk85's Photo Gallery
4th Generation installind a double DIN stereo in Gen 4 Camry w/ JBL audio package
Hi all,
This is my first post on the forum. I've had my 2001 Camry LE V6 for a few years now, and am installing a new car stereo. http://www.pioneerelectronics.com/PU...eer/FH-P8000BT
I have the JBL factory audio package. 6 speakers, including 2 tweeters in the door and a double DIN head unit. I'm replacing the head unit with the new Pioneer one. I read a post on here that said the JBL 6 speaker systems had an amp under the passenger kick panels, but I removed them and couldn't find anything that even remotely resembled an amp.
My question is: will I have any problems with the speakers if I just attach the new wiring harness to the existing wires inside the car?
My friend and I installed a similar deck in his Toyota Sienna minivan without any problems, but it was a simple 4 speaker setup. I'd appreciate any advice that's out there. Thanks a lot!
Jayhawk85 is offline   Reply With Quote
Old 04-09-2008, 12:49 PM   #2 (permalink)
xet
View xet's Photo Gallery
Usually when installing an aftermarket headunit installation, you bypass the factory amp, search around for it there are explanations on how to do it. Basically the new headunit puts out more and cleaner power than the factory amp anyway, you will be able to hear the difference. Good luck with your install.
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 04-09-2008, 12:59 PM   #3 (permalink)
DJT853's Avatar
View DJT853's Photo Gallery
Just a suggestion...consider changing your gauges and dashlights to blue so that they would match the head unit better. Other than that. looks excellent. Let us know how it looks/sounds
Dougy
My ride: The 2000 Camry LE I4 in Silver
DJT853 is offline   Reply With Quote
Old 04-09-2008, 01:33 PM   #4 (permalink)
Jayhawk85's Avatar
Alright thanks for the notes so far xet and DJ. I really like the blue dash lights idea. How difficult a mod is that and where might I find the parts?
Some instructions I've found on this site and others for the factory amp bypass mention a separate wiring harness. Is the one that comes with the stereo what they mean? Or is there something else I need to find to make this work? Thanks!
2001 Toyota Camry V6 LE ~90,000 miles
Pioneer FT-P8000BT deck (soon to be installed!)
Old 04-09-2008, 01:44 PM   #5 (permalink)
xet
You can just go to best buy and buy the wiring kit, it should be labeled. You just take that and splice it into your headunit one unless your headunit is coming setup for the camry...
There are some light changing guides as well, I got reverse glow gauges that match my HU at night pretty decently and I might do the rest of the dash lights sometime soon. I can give you some pics later tonight if you want to have a look at what I currently have
2005 G35 coupe 6mt
Old 04-09-2008, 04:43 PM   #6 (permalink)
Jayhawk85's Avatar
Question
"You can just go to best buy and buy the wiring kit, it should be labeled. You just take that and splice it into your headunit one unless your headunit is coming setup for the camry..." xet
I called Best Buy, they said the wiring kit costs $140. That seems insanely high... please tell me I'm right and I can do this myself for a hell of a lot less than $140.
Old 04-09-2008, 05:22 PM   #7 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
yes, you can do it for A LOT less than that. but by the same token, if you have to ask these questions...find a friend who can help you who has done this stuff before. otherwise...you could cross wires and fry your headunit+amp+speakers
as for your factory amp- if it's not under your seat, then it's behind the glovebox
HaHa
Old 04-09-2008, 05:37 PM   #8 (permalink)
xet
The kit should be like 20 bucks
http://www.bestbuy.com/site/olspage....=1051384099669
and you just cut the wires and match them up and then solder them together, get the crimp caps, or however you choose to do it
2005 G35 coupe 6mt
Old 04-09-2008, 05:47 PM   #9 (permalink)
Jayhawk85's Avatar
perfect
Thanks for the info xet, you're a champ. Stereo should arrive on Monday, if the weather is nice I plan on installing it after work. I'll let you know how it goes.
Old 04-17-2008, 02:14 PM   #10 (permalink)
Jayhawk85's Avatar
Alright, I picked up some crimp caps from RadioShack and a 20 dollar wiring harness from Circuit City and the install went great! I connected the harness I bought to the one that came with the deck, hooked everything up and in about 30 minutes I had everything working perfectly. All speakers, including tweeters sound great. The iPod connection and the phone connection are really handy and work well. The only thing left I'd like to do is wire the mic to the A pillar instead of the back of the steering column where it is now. But other than that, everyone's advice was great, thanks for the help!
Old 04-17-2008, 02:30 PM   #11 (permalink)
TN Pussy Man
good to hear
so did you end up using the pre-outs and converting them to use with the stock amp? or did you skip the stoke amp altogether?
HaHa
Old 04-18-2008, 12:51 AM   #12 (permalink)
View rawbi01's Photo Gallery
I just did the same. I have a '93 lxe with the stock amp under the seat. I bypassed the amp. It was easy. Once the head unit is out, you can see two more connectors, this is the wireing that leads to the amp and comes back to the head unit. By disconnecting these 2 connectors makes it easy to bypass the amp. You wire the harness from the new head unit into the connector that connects straight to the speakers. Because I used new speakers I left the tweeters in the doors unconnected. After I evaluate the new speakers I will re-connect the tweeters to see how they sound, I'll probably replace those as well, after all they are 15 years old. !
rawbi01 is offline   Reply With Quote
Old 04-18-2008, 11:35 PM   #13 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Originally Posted by Eye8Pussies View Post
good to hear
It sounds to me like he is still using the stock amp. If all he did was plug his HU harness into the one he bought..and plugged that one into the car...then he's still running through the stock amp.
Im posting and watching this because I have a 93 XLE with the same setup and will be doing this eventually.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 04-19-2008, 03:59 PM   #14 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
When I installed my headunit, i used crimp caps (twist two wires together and screw in a cap) and they work just fine. Also removing it is alot easier versus soldering.
Also, if you have to strip the wires, keep them short so the caps can completely cover the ends.
cruisn76 is offline   Reply With Quote
Old 05-08-2008, 03:13 PM   #15 (permalink)
Jayhawk85's Avatar
hot to bypass the factory amp
To answer the question about bypassing the factory amy:
Toyota in their infinite knowledge has given an extra wiring harness that is unused when the JBL audio package is installed. If you take out the factory radio and look inside the dash on the right side are two small white wiring harness that look like they are plugged into themselves. They are the built-in amp-bypass wiring harness. If you go to Circuit City and ask for a Toyota wiring harness (which is exactly what I did) they'll give you one that is in two parts that fits in these two previously-unused harnesses. Then crimp the ends of those wires to the harness from your new deck, and that's it.
I took pictures of the process and the location of the different harnesses in the dash, PM me and I'll email the pics to you.
Super easy, no re-wiring or pre-amps needed. You can also leave the original wiring harness in the car if you ever decide to sell the car you can install the old deck back.
