Check engine light came on for ~100 miles then turned off by itself - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2008, 12:35 PM   #1 (permalink)
View camry_98_owner's Photo Gallery
All
On my 1998 Camry, the engine check light came on for about 100 miles and then went off automatically by itself.
The reason I continued driving even after the check engine light came on was because I wanted to take it back to the service shop which did extensive work ($1500 worth) on my camry - so did not want to pay another shop to do a diagnostic test. But before I could make time to go to the shop it turned off by itself.
Should I be concerned?
thanks
camry_98_owner is offline   Reply With Quote
Old 04-09-2008, 12:42 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
some times somthing will cause it to come on for a short time. next time it does have the code checked.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-09-2008, 01:35 PM   #3 (permalink)
View sheepish_fixer's Photo Gallery
Originally Posted by camry_98_owner View Post
All
thanks
I would say no. If your oil is okay, your coolant level is fine and you're not overheating, you should be okay. My first guess would be 02 sensor..might have passed some moisture that set it off, then when it burned off, your OBD re-checked the system after 100 miles and detected it was okay...autozone (or maybe advance autoparts) will code your car for free...I'd hit them next time it happens
sheepish_fixer is offline   Reply With Quote
Old 04-09-2008, 01:43 PM   #4 (permalink)
View Gramps 750's Photo Gallery
My 1st question to you is did you put gas in your car recently, if so check and make sure the gas cap is tight. If it is not tight it will set the lite. If you put gas in it while it's running it will do it to.
Gramps 750 is offline   Reply With Quote
Old 04-09-2008, 03:04 PM   #5 (permalink)
Ahhh, Gas cap is a great guess....
Old 04-10-2008, 07:16 AM   #6 (permalink)
To bad it's not a quess it does cause the check engine lite to come on.
Old 04-10-2008, 07:25 AM   #7 (permalink)
agree - it's the best thing to check first
Old 04-10-2008, 11:58 AM   #8 (permalink)
No i did not pump gas recently into the vehicle. so no possibility of gas cap being not tight enough.
Oil - was topped when I did the 135 K service - including all belts replacement, all fluids drain and top off.
Coolant - the level should be good since the car is not over heating. I could nto check as my wife took the car today morning.
O2 sensors - does the OBD actually re-check every 100 miles? Because the light actually did turn itself off just after 100 miles - and that too while I was driving.
Thanks.
Old 04-10-2008, 12:34 PM   #9 (permalink)
yes, it does - maybe not 100 exactly, but anywhere between 75-150 miles on most car...at least that's what my Honda does...If I disconnect the rear 02 sesnor, the light comes on in 75 miles ...if I pull over, and reconnect the 02 sensor, the light goes off in 75 miles.
Old 04-12-2008, 08:59 PM   #10 (permalink)
Dude Wheres My Car?
nukem678's Avatar
View nukem678's Photo Gallery
Yes many of the senors like o2, egr, etc check themselves every pre determined number of miles. Or it could be a part on its way out. This happened to my beacuse of a bad vsv. The best thing to do is to check the code right when it comes back. I wouldnt worry about it too much but check it.
I lost my Camry in a parking lot once, Now it will never happen again
nukem678 is offline   Reply With Quote
