8 speaker system - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2008, 09:14 AM   #1 (permalink)
View Bluecam6's Photo Gallery
8 speaker system
Does anyone know how toyota wired the factory 8 speaker system in a 93 camry wagon? I want to upgrade the speakers and I put a pioneer reciever in already. The pioneer and the toyota reciever have 4 chaneels out to the speakers. Did toyota wire the 8 speakers by running 4 of them in paralle or in series. The only they could would be paralle or series..?????????????????????????????????????????? ???????????....Thanks
Bluecam6 is offline   Reply With Quote
Old 04-11-2008, 09:18 AM   #2 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
What model do you have? I know that the LE/DX had 4 speakers... and the XLE had 6... I don't know where you are getting 8 at?
BlueFusion6851 is offline   Reply With Quote
Old 04-11-2008, 09:32 AM   #3 (permalink)
It is a v6 le and the OEM window sitcker says 8 speaker optional system and a 6 disk changer. There are 2 speakers in the lower part of the front doors. 2 speakers in the top of the door pull handles. 2 speakers in the tailgate and 2 speakers in the side panels in the back on the wagon next to the window.
and the toyota disk changer is in the back drivers side next to the wagon fold down seat. the changer is under a carpet panel that is hinged up. the oppisite side of the spare tire........................????
Old 04-11-2008, 10:36 AM   #4 (permalink)
Gameroom cash: $924100
iTrader Score: 13 reviews
View ASG14's Photo Gallery
The Sedan's came stock with 4 (6 was the option), the wagon's had 6 stock (8 was the upgrade).
5 Lug Corolla WHAT?
Old 04-11-2008, 10:47 AM   #5 (permalink)
How hard can it be?
Forget about my post then... I need to be schooled.
Old 04-11-2008, 12:56 PM   #6 (permalink)
I just wanted to know how toyota wired the 8 speaker system so I can upgrade to better speakers. There is only 3 posibillities that toyota could have wired the system 1. run 4 speakers in parallel with the other 4 speakers. 2. run 4 speakers in series with the other 4 speakers. 3.run a type of crossover so that you only have miderange and tweeters sperately????????????????????????????............. ....................Anyone know???...........................
Old 04-11-2008, 01:20 PM   #7 (permalink)
I'm not at ALL an Audio guy, so I'll just say what I KNOW on my car (the upgraded 6 speaker system for the sedan)
The Tweeter has the crossover built on it. It;s just 2 wires to it that I think branches out from the 6.5" speaker.
The rear 6x9's are on seperate wires. If I remember correctly from installing my aftermarket radiop, there is 8 speaker wires (4+ and and 4- wires). 2 to each speaker area. So yeah, I guess that would mean the Tweeters are run off the same wire as the 6.5" speaker int he doors.
5 Lug Corolla WHAT?
Old 04-11-2008, 01:27 PM   #8 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
What year and model car do you have anyways? I can just see this being a 2002+ model, lol.
geoff5093 is offline   Reply With Quote
Old 04-11-2008, 01:45 PM   #9 (permalink)
View psyclemania's Photo Gallery
A bit of testing.
To be absolutely certain, you could easily figure this out with an ohm meter or continuity tester.
For example: figure out which is the RF speaker wires at the head unit (disconnected from head unit). Connect ohm meter. Go to the RF speaker wires (disconnected from speaker). Short the +/- with a jumper on one set of wires. If you get continuity, you have parallel wiring. Un-short and short the other set of RF speaker wires, continuity again? Definitely parallel. If you have to short both at the same time before you get continuity, then you have series. You could repeat this for all four corners, RF RR LF and LR, but I think it you figure one out, you will have it for all.
BTW, when I put my Infinity's into my camry, I just used the 6 1/2 speaker and that wiring, I unplugged the tweeter up topside by the mirror. It sounded much better that way. The additional parallel speaker was throwing the whole sound off, both electronically and acoustically. Let Infinity sound engineers do what we pay them to.
Sinister black 1999 Camry LE - 3.0L V6 5sp
35% tint / Grey leather / 15's ASA 5 dbl spoke / Sony/Infinity
psyclemania is offline   Reply With Quote
