Hi everybody!
My first post here is inspired by weird behaviour of my V6 Camry CE. It showed for the first time last winter. I have this car since September 2007 so I do not know how long this problem exists.
The symptoms are as following: time to time something happens to my car and it delays with shifting gears, upshifts and downshift. When I'm just starting the car after traffic light for example I accelerate very gently but RPM goes up to 3000 on hot engine and only then upshifts to second gear (without this problem it usually upshifts at 1600-1800). Same picture with shifting from 2-nd to 3-rd. When I slow down downshifts are delayed too and before shifting from 2-nd to 1-st gear RPM drops dramatically and engine tends to stall. One more thing: when I drive on some street with a lot of stop-and-go's after coming to full stop and depressing accelerator engine stalls for the moment but then returns to life again. Not after releasing brakes when car slowly starts moving but just after gentle depressing of accelerator. Delays with upshifting have one more interesting detail: no matter how I do accelerate upshifting will take place after some period of time. I mean I can push accelerator and rise RPM to 3000 and higher or I can accelerate it to speed at which upshift usually happens and then ease my foot from pedal - shifting will trigger after 'n' seconds in both cases. Seems like there is some timing device which doesn't permit upshifting until 'n' seconds over. Also switching from Parking to Drive or to Reverse is significantly harsh - car jolts back or forward and I'm starting to worry about my tranny, it won't last long after such hits.
This behaviour might start at any time and last for half an hour or several days and then spontaneously disappear. Also may be this is just coincidence but I noticed several times that if after I turn the key to ON position and right away start the engine - it starts roughly, RPM very low and the problem I described above is very likely to appear. If I turn the key to ON position, wait for 5..7 seconds and only then start the engine - it starts normally and, if I don't currently have that problem, it's unlikely to appear after such delayed engine start. ECU needs time to warm up?
As I said this problem started to show last winter, more precisely with first cold days. Most of the winter time I had this problem and I thought that this might be related to ATF (too high viscosity when cold). With warm weather this problem has disappeared but just recently returned back in pretty warm days.
I read error codes and sensors data with scan tool. Two error codes were recordered - P0120 (throttle position sensor "A" failure) and P0446 (evaporative emission system vent control circuit failure). Sensor data do not show anything extraordinaire, regular values. MIL light should be on but it isn't - bulb burned out? :-) Or dealer cut off the wire?
Somebody experienced same problem? Or maybe somebody can point out the problem based on symptoms?
Please anybody give me some suggestions.
Great thanks!
