AT transaxle pump re-install
Hello,
I pulled the engine and transaxel to fix a seal leak. I also pulled the transmission pump out to look at the bushing for the torque converter seal.
After putting the components back into the transmission, I noticed the shaft tightens considerably as I tighten the front plate holding the pump in.
Is this normal?
Should I be able to rotate the shaft even after the front plate is tight? I wondering if I have the plate too tight or something else not correctly in place before I put the engine and transaxle back together.
Also, any tips on making the "runout" measurement would be helphul.
Rick
