need help loud sound coming from timing belt area - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2008, 07:20 PM   #1 (permalink)
Royal Dreamz cc.
CJ Otey's Avatar
View CJ Otey's Photo Gallery
after my timing belt was change my car started to make a loud sound from the belt area on cold starts after the car warms up the sound gets quiter does anyone have and idea what it could be? its a 4cly
Two Toned 97 camry w/gen 4.5 front end conversion and 20" wheels and 2 Alpine Type R 15's in a vented box pushed by kicker zx1000.1
CJ Otey is offline   Reply With Quote
Old 04-14-2008, 07:33 PM   #2 (permalink)
ohgood's Avatar
View ohgood's Photo Gallery
sounds just like my maw-in-law's 99. my guess is it's the air pump. hopefully i'm right, and the end of the crank isn't about to destroy the rest of the engine
ohgood is offline   Reply With Quote
Old 04-14-2008, 10:49 PM   #3 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
iono what the problem is but it doesnt sound to healthy..
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 04-14-2008, 11:04 PM   #4 (permalink)
Royal Dreamz cc.
CJ Otey's Avatar
it started after i had a new timing belt put on, the old one had broke
Old 04-15-2008, 01:11 AM   #5 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Sounds like the belt slapping the plastic cover. Did you replace the Tensioner?
5 Lug Corolla WHAT?
Old 04-15-2008, 08:18 AM   #6 (permalink)
ohgood's Avatar
also, does the noise stop after the engine warms ?
Old 04-15-2008, 09:15 AM   #7 (permalink)
Royal Dreamz cc.
CJ Otey's Avatar
yeah it wasnt replaced at first but then i had it done to see if that would fixe it but it sounded the same im going to check the cover to see if it is hiting
after it warms up it stops and i dont hear it while driving and i dont hear it past 3000 rpms or under 1000 rpms
Old 04-15-2008, 10:13 AM   #8 (permalink)
The reason I thought it may be the belt is loose is because that is what happened on my dad's 96 I4 witht he original belt. Started at around 55k miles actually. IT sounded just liek that on a cold start, then slowly went away as the car warmed up.
5 Lug Corolla WHAT?
Old 04-15-2008, 10:17 AM   #9 (permalink)
Turbo Geo Prizm Owner
View toyotanos's Photo Gallery
Sound like the timing belt was not tensioned correctly (the lighter tap/slap noise). The 4 cylinder 5sfe doesn't have an automatic tensioner like the v-6. If the tension isn't set correctly, the belt will slap the upper cover at 2000rpm. If you had it done by a shop, they might not be familiar with that. The spring that is on the tensioner is not enough in most cases. You have to "assist" the spring by lifting up the tensioner more. PM me if you need a runthrough on how to adjust it yourself.
I drive all kinds of things. 1993 Geo Prizm LSI junk bucket, 1972 Honda CB450 supersport motorcycle, 1/18 scale stadium truck RC, 5' wingspan nitro RC Plane. They're all fun.
toyotanos is offline   Reply With Quote
Old 04-15-2008, 10:23 AM   #10 (permalink)
ohgood's Avatar
Will the sound dissappear after the engine warms up though ? If it's the belt slapping around, and a tension issue, I'll get into the process later next week on mine also. I can get the tensioning process from the FSM, or just finger it out either way.
Old 04-15-2008, 12:49 PM   #11 (permalink)
Sometimes it'll go away, I believe it to be the camshaft moving more smoothly with the warmed-up oil. But that's still just a guess. It does seem to happen more when it's cold.
Old 04-15-2008, 08:57 PM   #12 (permalink)
Royal Dreamz cc.
CJ Otey's Avatar
thanks for everyones help, i put the car back together today and the motor was knockin so i will be putting a new motor in soon
Old 04-16-2008, 06:13 AM   #13 (permalink)
ohgood's Avatar
I know that feeling. Sorry you've got to do that. Good luck with the 'new' engine.
