ELECTRICAL GREMLINS '92 4 cyl wagon - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2008, 01:07 PM   #1 (permalink)
View cpt444@yahoo.co's Photo Gallery
Question ELECTRICAL GREMLINS '92 4 cyl wagon
GREETINGS!
i have a 1992 camry wagon. for quite a while, the radio and clock have been intermittent; always both, never one or the other. initially, they would come on mysteriously and after a while only when when i hit a bump ... for the last several months, no matter what they have not worked.
now that i'm going on a loooong trip tomorrow, it's time to address this!
can Anyone help?
Many Thanks in advance!!!
chris in ny
cpt444@yahoo.co is offline   Reply With Quote
Old 04-15-2008, 03:28 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Evidently they share a common power wire or ground wire (or both) and one or the other has a loose connection or the wire itself has broken. Since it no longer works at all it will be fairly easy to determine which is bad. Get you a multi-meter and go to town. You could start at the fuse panel and check there first. If you have power at the fuse I guess you will need to pull the radio from the dash and start testing from there.
Do a search for ideas on how to disassemble the dash to get at the radio.
Kep
