I'm not sure that I would bother with the oil seals (oil pump, cam shaft, harmonic balancer), unless they are leaking, unless you just want to go the extra mile while you have the TB out. The manual should give you a mileage to change the diff fluid. I would imagine that it is about every 30,000 miles (60,000 km?).
Consider replacing the brake fluid. Clean the PCV valve. It would be interesting to pop the valve cover and determine if you have any sludge concerns (though I haven't taken my own advise on this yet). However, this could cost you the price of the 5 gaskets on a 5SFE.
Kep
