1992 camry synthetic oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2008, 09:50 AM   #1 (permalink)
View rqb2001's Photo Gallery
I have a 92 2.2 L camry with 219,000 miles on it. Would it be feasible to switch to mobil 1 synthetic oil?
rqb2001 is offline   Reply With Quote
Old 04-17-2008, 09:52 AM   #2 (permalink)
View J_Phu's Photo Gallery
A car with that much miles on it, I wouldn't use synth. You'll will see alot of leaks.
J_Phu is offline   Reply With Quote
Old 04-17-2008, 10:11 AM   #3 (permalink)
djangelouz's Avatar
View djangelouz's Photo Gallery
He is right it s not worth putting syth oil in that many miles.
djangelouz is offline   Reply With Quote
Old 04-17-2008, 01:32 PM   #4 (permalink)
Banned
View TRD_EarBanger's Photo Gallery
It doesnt make any sense, dino took you this far didnt it, also it is already nearing the end of the wear cycle
TRD_EarBanger is offline   Reply With Quote
Old 04-17-2008, 02:07 PM   #5 (permalink)
View llcoolpass's Photo Gallery
synthetic is just fine, it is not going to leak anymore. the early synthetics did the leaky thing, and now they got a bad name , even though they're fine now.
if you sw, and you think the engine is getting tired, i would go up a notch in term of grade. e.g. if you've been using 10w30, go to 10w40
1993 Lexus ES 300 [completely stock] -- 5-speed Manual V-6 3VZ-FE -- Curb Weight 3,570 lbs; Mileage 152,000 -- 0-60mph http://www.youtube.com/watch?v=ygwUh1MZRLM
llcoolpass is offline   Reply With Quote
Old 04-17-2008, 03:19 PM   #6 (permalink)
View mvftw's Photo Gallery
I've had good luck with this so far...
http://www.valvoline.com/pages/produ....asp?product=7
mvftw is offline   Reply With Quote
Old 04-17-2008, 03:45 PM   #7 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
synthetics don't cause leaks. If they leak it was because the leak was already there, they last longer while still providing equal or greater wear protection, and in general out-perform dino oils. I switched my Scepter to synthetic at 150K miles and never had a single problem, the oil held up better in every way (and i drive HARD).
While 219K miles is pretty extreme, switching to synthetic won't hurt the car. i guess the real question is, is it worth the added cost for a car that is closer to the end of its life than the beginning?
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 04-17-2008, 08:00 PM   #8 (permalink)
ecale3 ,
true true true
-brian
Old 04-18-2008, 11:38 PM   #9 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Nowhere near the end of the life of that engine.....switch if you want the cost. It will work just fine. My LE in my sig has NEVER seen synthetic and still runs just great!
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 04-19-2008, 04:07 PM   #10 (permalink)
mr.pringles's Avatar
View mr.pringles's Photo Gallery
It's definately not worth it. If you've been using conventional oil the whole car life, then stick with it. Changing to something new may not be the best as if its already used to the old.
92' Camry 5S-FE 179k mi SOLD
96' Camry 1MZ-FE 110k
DDMtuning 4500k HID Kit AutoPage C3-RS665 Remote Start/Alarm Home Depot CAI
mr.pringles is offline   Reply With Quote
