Fuel Pump Access on Wagon - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2008, 05:18 PM   #1 (permalink)
View toyomoho's Photo Gallery
A friend has a 1995 Camry station wagon and is trying to access the fuel pump in the tank. He states he has removed the rear seat but finds only carpet. The sedan has no carpet under the lower seat and removing it reveals the pump cover.
Does anyone know how to access the pump on the station wagon, does the complete carpet need to be removed?
Old 04-19-2008, 09:42 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
No personal experience. My manual does not show any provision for pulling the carpet. Is it possible that it has been recarpeted and not left open? If you can feel the fuel pump cover you might try cutting the carpet with a razor (make an "X" in the carpet over the assembly). Remember, watch out for the wires and the like when cutting. and don't cut past where the seat conceals the cut.
Kep
Old 04-21-2008, 10:01 AM   #3 (permalink)
Thanks for your reply Kep.
The owners states the carpet is stock. The info I have also has nothing on accessing the pump in a wagon. As you would assume the tank location must by the same as the sedan. Have taken pump cover location measurements from a 1995 sedan and passed them on.
Kind of strange Toyota having no removable section of carpet on the wagon.
Old 04-20-2010, 09:47 AM   #4 (permalink)
Nervous's Avatar
Gameroom cash: $275064
View Nervous's Photo Gallery
Hey, I am having the same problem! I was going to test a fuel pump in the wagon and found the carpet only. Does anyone have any experience with accessing fp in wagons (don't want to break anything....)?
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
FOR SALE, Sedan/Wagon parts
Nervous is offline   Reply With Quote
Old 04-20-2010, 10:29 AM   #5 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
you need to pull up the carpet. it is in the same place as the 4dr or coupe. do not cut the carpet!!!! just move it. i own a wagon and prefer this way cause it keeps my car clean.
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
The Following User Says Thank You to 2wickedtoyz For This Useful Post:
Nervous (04-20-2010)
Old 04-20-2010, 10:34 AM   #6 (permalink)
Nervous's Avatar
A there any clips/screws holding the carpet?
Old 04-20-2010, 10:44 AM   #7 (permalink)
Mad Scientist
it's been awhile so i need to look at mine.
Camry Wagon Crew
Old 04-20-2010, 05:14 PM   #8 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
step by step: http://www.**********s.com/camry/
'07 Honda Ruckus Big Bore
Old 04-20-2010, 05:24 PM   #9 (permalink)
Nervous's Avatar
Oh, common! It doesn't have info about how to remove carpet in wagon.
Old 04-20-2010, 05:53 PM   #10 (permalink)
Freakin Scooters
Really?
http://www.**********s.com/camry/bo.pdf Page 120 or so will get the seats out. Lots of interior stuff here... you could strip the entire interior with this PDF. Read carefully. You're probably going to have to remove trim pieces around the edges so you can pull the carpet back.
http://www.**********s.com/camry/eg2.pdf Pages 230-239 talk about fuel pump maintenance.
Also, "come on" is two words.
The Following 2 Users Say Thank You to LynchburgCSI For This Useful Post:
2wickedtoyz (04-20-2010), Nervous (04-20-2010)
Old 04-20-2010, 06:12 PM   #11 (permalink)
Nervous's Avatar
Ok-ok, you got me with "c'mon". Thank you!
Old 04-20-2010, 08:26 PM   #12 (permalink)
Mad Scientist
nice way to come through my doors are locked and the wagon is full of parts so i can't get to it
Camry Wagon Crew
Old 04-21-2010, 09:01 AM   #13 (permalink)
Nervous's Avatar
Regardless to the fact that FSM is useless here, I guess I found two clips holding the carpet (behind the seat back). It is also helpful to remove two side pillows. Carpet there is really hard and it is not that easy to remove it. Another challenge will be to put it back.... Thanks to everyone!
Old 04-21-2010, 03:07 PM   #14 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
I accessed pump cover on my wagon. Only way is to cut back the carpet. Toyomoho, you once gave me a close approximation of the sedan's cover location when this issue came up on another forum. I used that to locate where to cut the carpet. The cut only has to be enough to peel back the carpet for enough access. Base the location on a sedan's.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 04-21-2010, 03:28 PM   #15 (permalink)
Nervous's Avatar
No, I don't want to cut carpet and I am sure it is possible avoid this. I'll post pictures after I do this.
