Remote Starter 1995 Camry wont run? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2008, 01:59 AM   #1 (permalink)
View oxygen69's Photo Gallery
Question Remote Starter 1995 Camry wont run?
Hey Guys,
I was wondering of anyone could help me figure out why the remote starter isn't running my car.. the motor turns over, but the engine does not startup. It is a 1995 Camry LE, I think that there is a dual ignition starting key that I probably have wrong, but I have one of the wires hooked up to the relay box under the hood, and tried hooking the other wire up, but am not sure what im doing wrong.. Here is some info:
DTS-1444 (Datastart Remote Starter)
Pin-1 30A Fuse +12v (Red) (+) "Constant +12v hooked to battery"
Pin-2 Heater/AC (Green) (+) "Accessory wire"
-Connected to Junction box (2G)#6 (Black & Orange)
Pin-3 Starter (Yellow) (+) "Solenoid side of start wire"
-Connected to Junction box (2C)#2 (Black)
Pin-4 Programmable (Orange) (+) "Programmable for 5th onboard relay for vehicles that require a 2nd ignition/Accessory/Starter"
-Connected to ??? unsure where to connect tried many different places and all didn't work
Pin-5 Ignition (Blue) (+) "Ignition switch"
-Connected toJunction box (2C)#3 (Black & Orange)
Pin-6 30A Fuse +12v (Red) (+) "Constant +12v hooked to battery"
The Troubleshooting thing says that some possible options are:
-2nd ignition is not connected
-2nd starter wire not connected
-Ignition wire not connected
I think I need to connect the Pin-4 wire to somewhere, but I don't want to go into the dash, but would prefer to try to be in the engine compartment.. I already ran 4 wires back and forth..
I have tried hooking it to:
-(White & Red) wire in ignition coil--Not good!
-(Back & Red) wire igniter --Not good!
-(Black) wire igniter --Not good!
Please help!
Oxygen69
oxygen69 is offline   Reply With Quote
Old 04-21-2008, 11:01 AM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I am afraid that I won't be of any use but I am interested in how this turns out. I would kind of like to do this to mine. What name brand is the unit that you are installing? I don't want the remote start feature so much as being able to open the door locks remotely. Will yours do this?
Kep
Old 04-21-2008, 11:10 AM   #3 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
When I installed my remote starter tapped into the ignition harness under the steering column. I know that there is an "ignition1," "ignition2," "acc," and "start" wire that have to be connected. I'm guessing that you don't have"ignition2" connected. I found it easiest to tap into the wiring harness under the steering column/ dash. Sorry, but I don't remember any of the color codes anymore as it was 3 years ago.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
