Low idle speed when start cold engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2008, 07:00 AM   #1 (permalink)
View camry98cool's Photo Gallery
3rd Generation Low idle speed when start cold engine
I had starting problem before, see:
Engine hard to start when cold or wet
First I replaced the dirty front ignition coil, it was same as before. Then I replaced the valve head gasket and coolant temp sensor, then the cold engine could be started without pressing gas, but the idle speed is very low (~400 rpm) almost can stop immediately, but it always struggles to start, after driving for a while, everything goes well. Now I am doubting the K&N air filter might be added over amount oil so it affected something or some fuel leaking or sensor problem?
Any suggestions will be appreciated!
camry98cool is offline   Reply With Quote
Old 04-20-2008, 08:59 AM   #2 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
Could well be the IAC valve as mentioned in the other thread. This is a common problem. Have you cleaned it yet?
DFBonnett is offline   Reply With Quote
Old 04-21-2008, 10:55 AM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
You might want to troubleshoot the Engine Coolant Temperature (ECT) sensor. The ECM uses that to determine the appropriate mixture for a cold or warm engine.
Kep
Old 04-21-2008, 02:47 PM   #4 (permalink)
More than two persons said it wasn't matter with IAC valve, so I didn't do anything on it
Old 04-21-2008, 02:48 PM   #5 (permalink)
Kep
Yes, I replaced ECT as suggestions, nothing changes
Old 05-04-2008, 07:05 PM   #6 (permalink)
Problem solved!
After replacing Idle Air Control (IAC) valve, the problem was solved! A Toyota expert told me that this is a common problem for camrys
