'95 Camry Main Power Fuse Blown - Power Windows
So, I've been deperately trying to figure out why my Main Power Fuse keeps blowing out everytime I turn on the ignition. This is why I'm here. I hope you guys can help.
I pulled the Power Window Relay and that stopped the fuse from blowing, so I have my power door locks back.
I've pulled the master switch and the other door switches and checked continuity on each switch - everything seems ok.
After I pulled each switch, I put power directly to the window motors and they went up and down without a problem.
I then sent power from the car battery through the main control switch connector and three out of four windows went up and down (the right rear window did not).
However, I checked continuity from the main swith connector to the right rear door window, and I have continuity. I'm completely perplexed (or maybe not).
I think that the insulation on one of the wires going to the right rear window became worn down and it is shorting out on the chassis. This would explain a short and having continuity.
But, then why am I not getting the window to go up and down when sending power through the harness?
And, why does the main power fuse blow when I turn on the ignition, ince there shouldn't be a load without depressing the main or door switch?
If anyone has some knowledge to share, I would greatly appreciate it.
