help please - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2008, 09:29 AM   #1 (permalink)
View Idrum88's Photo Gallery
help please
I just recently replaced my 4 cyl motor on my 93 camry and i need some help locating something. On the automatic transaxle there is a speed sensor. It is the #2 speed sensor i believe. The speed sensor is not plugged in and I can not seem to locate the wire that plugs into it. The speedo is not working because of this and the transmission is acting up as well. Where should the wire be coming from and what part of the harness is it located?
Thanks
Idrum88 is offline   Reply With Quote
Old 04-21-2008, 10:31 AM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Try the wiring diagram at http://www.camrystuff.com/ Go to the Gen 3 and select the 1994 Wiring diagram. Search for "speed sensor". Page 31 shows the one that I think you are looking for.
Kep
