Noobie need help with Big 3 upgrade (pics) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2008, 10:07 AM   #1 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
3rd Generation Noobie need help with Big 3 upgrade (pics)
I have a question about the Big three upgrade and I'm trying to do it myself...
which one of these pictures is the positive part? I got confused and I didn't have a multimeter with me I let someone else borrow it. Yeah I know I have the dirtiest engine bay on TN... would it still work on a 70 amp alternator? I paid someone to do it for me last time I want to try it this time.
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 04-21-2008, 10:16 AM   #2 (permalink)
JayMax03's Avatar
is this the spot where I would put freon in for the AC?
Old 04-21-2008, 10:40 AM   #3 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
The second pic is the positive lead.
Yes that is where you would put in freon.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 04-21-2008, 11:37 AM   #4 (permalink)
JayMax03's Avatar
so the first pic is the negative lead then?
Old 04-21-2008, 11:40 AM   #5 (permalink)
'95 Camry 5S-FE
No, the case of the alternator is the negative lead, aka ground.
The first pic is a connector for other stuff like the regulator.
Old 04-21-2008, 04:02 PM   #6 (permalink)
View frojoe's Photo Gallery
As 95 said the second pic is the positive. I included a few pics of by big three to help. I hooked the alternator negative straight to the case instead of the engine but that isn't important.
frojoe is offline   Reply With Quote
Old 04-22-2008, 11:31 AM   #7 (permalink)
JayMax03's Avatar
is this a good grounding spot? I know I need to sand the paint off of it, but it still works...
Old 04-22-2008, 12:19 PM   #8 (permalink)
that will probably be alright, but wouldn't it have been easier to just unscrew one of the other bolts there and put the ring terminal underneath?
Old 05-11-2008, 05:53 AM   #9 (permalink)
JayMax03's Avatar
didn't have the tools at the time, so I just took a phillips and forced it down
Old 05-11-2008, 01:12 PM   #10 (permalink)
xet
View xet's Photo Gallery
what wire did u use?
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 05-11-2008, 08:21 PM   #11 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
BTW...that is where the freon goes in..but if it hasnt been converted from r12 to r134, then you'll prolly need a shop to do it for you, and it wont be cheap.
If it has already been converted and just needs a little more in there, then you can do that yourself.
But by the looks of it..it hasnt been converted because it doesnt have an adapter on it. You cannot mix r12 and r134a.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 05-11-2008, 10:56 PM   #12 (permalink)
JayMax03's Avatar
Stinger 0 Gauge wire
Old 03-09-2009, 05:58 PM   #13 (permalink)
View Manny1337's Photo Gallery
i have a question about the 3rd pic in connecting the wire to the alt. did you break that plastic clip off i tried to take it off on mine and it wouldn't move, what is under it and how do you connect the wire to it =P
1998 Camry I4 2.2 Currently: 110k
Alpine Ida-x100, Polk Momo 6x9 (Rear), Polk DB651 (Front), Infinity Reference 475a, AudioQ Aq-1200, 4 Re X 8's <-- yes she slams
Manny1337 is offline   Reply With Quote
Old 03-09-2009, 06:05 PM   #14 (permalink)
Do you mean that gray thing with blue electrical tape? if that's what your talking about mine was soft rubber. I just pulled it up, took out the bolt underneath it, then added a ring terminal and reattached the bolt. The only reason there is a hole in the rubber thing is that I cut it so that it would seat right over the new wire. Since then I have replaced the electrical tape with shrink tubing to make a more permanent solution.
Old 03-09-2009, 06:09 PM   #15 (permalink)
yea that is what im talking about. thanks for the help
