2001 Camry Rattle Rattle Clunk Clunk - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2008, 10:43 AM   #1 (permalink)
View red73mustang's Photo Gallery
My 01 is making a noise up front and I was looking for some input. I have inspected and ruled out the CV joints, however the top "dogbone" engine mount is badly worn + the engine will rock forward when put in reverse with the brake on so I suspect the mounts are the culprit. Are there any other possible suspension components that could make such a loud noise (sway bar links?)
Thanks,Chet
red73mustang is offline   Reply With Quote
Old 04-22-2008, 12:21 PM   #2 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
Strut mounts could also be a possibility.
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 04-22-2008, 01:45 PM   #3 (permalink)
kungkool's Avatar
View kungkool's Photo Gallery
USA I ditto the struts
My 2000 did the same thing. Started out as just a small noise and gradually got worse. I would check the struts.
2000 Camry CE
kungkool is offline   Reply With Quote
Old 04-22-2008, 02:59 PM   #4 (permalink)
Hmmmmm...... Started out small noise and gradually got worse....I checked all the strut mounting bolts and everything seams tight. Could the struts make a loud clicking noise if they are shot?
Old 04-22-2008, 05:29 PM   #5 (permalink)
[quote=red73mustang;2299334]Hmmmmm...... Started out small noise and gradually got worse....I checked all the strut mounting bolts and everything seams tight. Could the struts make a loud clicking noise if they are shot?
Riddle me this Batamn, Strut mounts is a round looking plate that goes between struts and body and is like a bushing? I am starting to suspect the strut mounts too. Globbed some silicone sealer on the "Dog bone" engine mount to quiet it down, if no improvement I better get at those strut mounts.
Update: Well after sealling up the upper "dog bone" engine mount with good ole bath tub silicone the noise is mostly gone so I plan on replacing all the engine mounts soon.
Update 2: !!! Noise came back, so I checked the center bolt on the strut and it was loose as a goose, a few turns with the 19M socket and the noise is completely gone, thanks for all the help!
