DIY replace bulbs for leds, a/c console etc gen4 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2008, 07:31 PM   #1 (permalink)
Don't get mad. Get even.
El Tano's Avatar
View El Tano's Photo Gallery
4th Generation DIY replace bulbs for leds, a/c console etc gen4
OK guys, finally had some time to do this..
I hope it helps..
Make a hole the size of the led on the right side of the panel
Make another hole on the left side
Now you have 4 leds
I ran the wires and connected to the ashtray light with a plug to make it easy to remove the front.
Done, put everything back togheter.
  • Now let's go to the ignition light
  • Now let's go to the glove compartment
Pull it out
I used #74 leds for all this..
I also tried this first and it worked pretty good but all the damn leds burned after 2 minutes , I took them appart from a panel and I think they had some little resistors so they don't burn...
Also get some blue tape around the center console to protect the area from scratches..
Sorry for the crappy DIY but I'm not patient and this thing takes a lot of time
DISCLAIMER: I'm not responsible for any damage that can occur to your car, do this at your own risk..
El Tano is offline   Reply With Quote
Old 04-22-2008, 07:34 PM   #2 (permalink)
El Tano's Avatar
I have the dash comming, so stay put....
Old 04-22-2008, 07:57 PM   #3 (permalink)
'_'
Touge Star
'_''s Avatar
Gameroom cash: $421512
iTrader Score: 10 reviews
View '_''s Photo Gallery
Nice DIY . I've only done the dash so far, and it wasn't too bad. Do you have any pics of the HVAC unit with the LED lights on?
山道だいすきです。
http://www.cardomain.com/ride/2538603
'_' is online now   Reply With Quote
Old 04-22-2008, 08:12 PM   #4 (permalink)
El Tano's Avatar
I'll post some later
Old 04-22-2008, 08:24 PM   #5 (permalink)
nuchieboy's Avatar
Gameroom cash: $203299
View nuchieboy's Photo Gallery
4th Generation
thats sick i def want to do my hvac controls and gauges in leds!
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
nuchieboy is offline   Reply With Quote
Old 04-22-2008, 11:44 PM   #6 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
Was it too dim with just two #74 LEDs in the stock Climate Control Backlit locations?
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 04-23-2008, 12:48 AM   #7 (permalink)
El Tano's Avatar
Yes, well basically uneven light, not enough light on the sides
Old 04-23-2008, 10:17 AM   #8 (permalink)
ELL
ELL's Avatar
View ELL's Photo Gallery
Hey,
do you have any pictures of it at night with the lights on? I'd liek to see what it looks like
2000 Camry LE I4.
ELL is offline   Reply With Quote
Old 04-23-2008, 02:55 PM   #9 (permalink)
El Tano's Avatar
Here it is, sorry for the pic but I suck at taking pics
And here a pict of my latest mod...
Old 04-23-2008, 02:58 PM   #10 (permalink)
'_'
Touge Star
'_''s Avatar
Looks great. The last pic you posted of the HVAC unit, was that after you installed 4 LEDs? If so, how bad is the light output with only 2 LED's there?
山道だいすきです。
Old 04-23-2008, 03:02 PM   #11 (permalink)
nuchieboy's Avatar
4th Generation
im guessing but im think thats 4
Old 04-23-2008, 03:22 PM   #12 (permalink)
El Tano's Avatar
The blury pic it's with the 4 leds, with 2 leds it's pretty bad, as I stated before on a post above, the light it's uneven, since the leds send the light straight you only have light on the center area of the controls, that's why I added one more on each side..
Note: I noticed that behind the front of the cover the coat of white paint it's thicker on the center and thiner as it goes to the sides, they did this because the oem bulbs are located on the center area and this way it distributes the light more even.
Old 04-23-2008, 04:06 PM   #13 (permalink)
nuchieboy's Avatar
4th Generation
i wonder if you use 2 leds but use tin foil like some people have used on the gauge cluster to more evenly distribute the light would work
Old 04-23-2008, 05:04 PM   #14 (permalink)
ELL
ELL's Avatar
Yup, that would work to disperse the light more evenly throughout, though i'd recommend pieces of polished aluminum more than tin foil for a better looking spread
2000 Camry LE I4.
Old 04-23-2008, 05:05 PM   #15 (permalink)
ELL
ELL's Avatar
Nice pictures, though I wish i had that thing under the rearview mirror like you do!
Great DIY, i may have to try this once my bigger mods are finished
2000 Camry LE I4.
