A 95 Camry likely has enough miles on it to warrant going in and doing basic cleaning. I would propose the throttle body, EGR, EGR Modulator, the vacuum lines between the two, and the IAC valve (on the 4 cyl you can remove it once the TB is off). Just for grins and giggles do the PCV valve too. If that doesn't rectify the problem more trouble shooting will be necessary.
Please let us know of your progress!
Kep
