93 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2008, 11:28 PM   #1 (permalink)
View Idrum88's Photo Gallery
93 camry
i just replaced the engine on my 93 camry and i reused the auto transaxle. When i first drove it the engine ran fine but when i put it in drive it doesent pop into drive like normal but i have to press the gas some and then it slides into gear. I know the trans is not bad cuz it was perfect before i pulled the old motor... i know there are some adjustments that i can probably make to fix this but i need to know what to do.
Thanks
Idrum88 is offline   Reply With Quote
Old 04-23-2008, 09:27 AM   #2 (permalink)
bump
Old 04-23-2008, 09:40 AM   #3 (permalink)
View mvftw's Photo Gallery
Check the tranny & Diff fluid...
mvftw is offline   Reply With Quote
Old 04-23-2008, 09:47 AM   #4 (permalink)
could the diff fluid cause this to happen?? and could the dipstick on the transmission be wrong? When i swapped the motor i lost alot of transmission fluid but the dipstick still reads full??
Old 04-23-2008, 09:59 AM   #5 (permalink)
View J_Phu's Photo Gallery
Was your engine running and your tranny is in neutral when you checked the dipstick
J_Phu is offline   Reply With Quote
Old 04-23-2008, 12:37 PM   #6 (permalink)
it was in park after a 30 mile drive
Old 04-23-2008, 03:11 PM   #7 (permalink)
well after a 30min drive the engine and tranny gets pretty hot, so that could cause a miss read of the dipstick. Try looking again wen the engine is only warmed up with no driving or anything and see if the dipstick still reads full.
Old 04-23-2008, 03:29 PM   #8 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
^ Make sure the engine is running when you check the tranny fluid level too.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 04-23-2008, 04:09 PM   #9 (permalink)
View letseatpaste's Photo Gallery
Ahh, I missed your post before I just started this thread a few minutes ago. I'm having the same problem.
Trouble shifting into drive and reverse
letseatpaste is offline   Reply With Quote
