1MZ V6 Timing Belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2008, 05:25 PM   #1 (permalink)
Quattrovalvole's Avatar
View Quattrovalvole's Photo Gallery
4th Generation 1MZ V6 Timing Belt
Hello to everyone
My name is Henry and I am from Costa Rica.
I just bought recently a 1997 Toyota Camry V6. I really like this car since my father had a secong gen Camry.
I want to change the timing belt and i wanted to know if someone has the diagram and what parts would you recommend to change with the belt. By the way this is not an interruption engine. Right?
I need to order all the replacements parts from the US since here isn't a common car.
I am familiar with Toyota since I had a 1987 Tercel a few years a go, but it is always good to know what you can recommend.
My mechanic is really slow so I want to take to him all the parts, because he needs an entire life to order them.
I will appreciate all your comments.
Thanks
Quattrovalvole is offline   Reply With Quote
Old 04-23-2008, 06:06 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $359260
iTrader Score: 13 reviews
lol...I like your english expressions....especially about your mechanic...haha...
bot more on topic...yes, the engine is a non-interference engine, so if your timing belt breaks, you'll still be fine. just stranded.
as for the diagram on how to change them, your best bet is to pick up a haynes manual- it'll tell your mechanic everything that he will need to know, since he will know the rest that is engine specific.
for parts, you can try rockauto.com
but shipping is going to be expensive no matter where you get your parts from I think
HaHa
Old 04-23-2008, 06:19 PM   #3 (permalink)
Hi Eye 8
What can I say, lol..... it takes forever to him to order parts.
Have you ever done this job? Which parts you replaced?
Thanks for the adress I am looking it......
Old 04-23-2008, 06:58 PM   #4 (permalink)
'94 V6 Auto
View Kevin89AllTrac's Photo Gallery
Parts
Quattrovalvole, I did mine TB last year, replacing these parts:
  • water pump, Aisin f/AutohauzAZ: $80
  • timing belt, Mitsuboshi f/AutohauzAZ: $31
  • drive belts, Bando, f/AutohauzAZ: $20
  • spark plugs, NGK laser iridium f/Autozone: $48
  • antifreeze, Zerex G-05 f/Autozone: $22
  • coolant bypass hose, local Toy dealer: $11
I used mostly AutohauzAZ (http://www.autohausaz.com/) because they had the best price, including shipping, for OEM parts. My car had only 75K miles on it at the time so I didn't replace the cam & crank seals, or the tensioners. I replaced the bypass hose and sparkplugs at the same time, but if you're just doing the belt/waterpump, no need for those parts.
Good luck!
Kevin89AllTrac is offline   Reply With Quote
Old 04-23-2008, 07:07 PM   #5 (permalink)
'94 V6 Auto
Forgot to add: The Autozone website has excellent DIY pic's/instructions for 1MZ timing belt replacement. Better than the Toyota manual in many cases, IMHO. Take a look.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Nothing for your '97, but I don't think it's too different from a '96.
Old 04-23-2008, 07:51 PM   #6 (permalink)
TN Pussy Man
^ ah, those were the ones that I was trying to find, but I only kept coming up with partsource's stuff
and all the 1mzfe's are identical when it comes to timing belt change
as for parts:
- timing belt
- power steering belt
- camshaft seal
- crankshaft seal x2
- new idler pulley
- new tensioner pulley
- new tensioner (optional)
- water pump + gasket
then, if you want to, the sparkplugs, thermostat, rad hoses, etc.
the coolant in the block will have to be drained anyway, so it wouldn't be a bad time to do the thermostat
HaHa
Old 04-23-2008, 10:06 PM   #7 (permalink)
Strum's Avatar
View Strum's Photo Gallery
What exactly is that? Nothing elaborate and how do you find out if you have that type of engine?
Mark
1993 Camry 6 cyl. (142K),
1998 Camry 4 cyl. (140K)
1996 Corolla (227K), 1997 Corolla (167K),
Strum is offline   Reply With Quote
Old 04-24-2008, 02:38 AM   #8 (permalink)
Dodge Man
modian's Avatar
View modian's Photo Gallery
An interference engine's valves will open to where their lowest point in travel is below the piston's highest point of travel. Should the valve be stuck open there and the piston continued moving it would came up to smack the valve. Bad things will happen. As long as the valves are in correct time and continue to move in synchronicity with the pistons they will never collide. When the timing belt breaks the valves stop moving while the piston continues to move as the crank spins. One or more valves are bound to be encroaching on the pistons' travel.
A non-interference engine's valves and pistons never move into the other's
range of travel. A broken timing belt causes no damage to the hard parts.
Someone else will need to chime in with where to find reference info on what engines are and are not interference types.
His - 2002 Graphite QC SLT Plus, 4.7L, NV3500, Superchips 3715, 3.92 LSD, R/T rear swaybar, no chrome, loads o'fun...
Ours - 2001 Patriot Blue Durango SLT, 4.7L, 45RFE, Superchips 3715, 3.55 Open (for now)
Hers - 1997 Green Avalon XL
modian is offline   Reply With Quote
Old 04-24-2008, 03:34 AM   #9 (permalink)
Biscuit-Dough Hands
Lumberg's Avatar
View Lumberg's Photo Gallery
Yo vivi en San Jose por unos anos. Hay un manual en PDF format que puedes encontrar en capitulos por este sitio.
Green Camry R.I.P.
Black Camry R.I.P.
2004 Avalon
iPhone repair, cell phone repair in Washington DC, Rockville Maryland
Lumberg is offline   Reply With Quote
Old 04-24-2008, 10:47 AM   #10 (permalink)
Thanks everybody for the comments you made my life lot easier.
Old 04-24-2008, 10:50 AM   #11 (permalink)
Hola.
Gracias por la respuesta ¿Hace cuánto viviste por acá?
Old 04-24-2008, 11:13 AM   #12 (permalink)
Biscuit-Dough Hands
Lumberg's Avatar
Hola.
Hace como quince anos, mas o menos.
Green Camry R.I.P.
Black Camry R.I.P.
2004 Avalon
