Pics coming tomorrow.
I spent the day...ALL day...working on it. All the lights are off it, and the grille, and the rear window trim, and the bumper strips on each door, and if I can figure out how to remove the window trim, it'll come off,
too. But the bumper skins look like a cast-iron nightmare to remove for rework, so the heck with it,
I don't want to spend an entire day removing them. They stay on the car, and the rear one got a near
full skim coat of claw glaze, and tomorrow the front gets the same.
My best work so far was to a dent on the near-flat back of the trunk lid, right over the V6 badge. It had
a nice little dent there that I put in myself, a while ago. That sucked! Well, I'm not all that
experienced at bodywork, but I got some lessons from a friend. And I did the repair there, and had
to "adjust" it a couple of times, but it's RIGHT. I'd say flawless. I can't feel a problem, I can't even
see it with the area wetted down and looking at the shine from any angle. I'm rather proud of that. [
The prospect of cleaning inside the wheelwells is absolutely frightening. [:/] But I'll need to do it in
order to make the work look like it's a LITTLE more than skin deep. I might have to clean them with
a wire wheel brush on a drill, at least for the first half inch of crud or so. [;D]
I'll probably spend a good two hours detailing out the engine compartment, under the hood, and under
the trunk lid. And I've got to figure out how to remove the washer jets from the hood.
I'm in absolutely no hurry but as I've taken all the lights off the car, I'm definitely committed to working
on it all I can until it's done. I can't borrow another car forever!
I'm buying a few more new parts for it. The big rear taillight assembly on the trunk lid, for one. It's not
cheap, but it's the biggest piece on the car that I can't really refurbish. Heck with it, I've got the money,
and I'll store the old one just in case someone breaks the new one some fine day.
I found that the snap-in retainers that hold the front bumper skin in place, between the frame and
the clamping bar, have all pretty much disintegrated. Of course, I can't order those until Monday,
but they're easy to install once I get them. So far, that's the ONLY part that I've found that's actually
broken due to age out of every body part I've yet touched.
I think I'll go with clear marker lenses up front. I found an ebay seller who's got 'em, but frankly I don't
really trust him much since one of the links on an auction of his triggered my anti-virus software and
reported a dangerous trojan used by phishers. I'd like to have an alternate source that doesn't come
with free trojans or viruses.
With ANY luck, the car will be ready for primer by tomorrow evening, if not actually primed. But
I'm not even considering the possibility of getting farther than that so soon. I won't rush this job,
because I want this to be gorgeous and this is as demanding ia finish as a single solid color finish
can possibly be.
The finish is DuPont G9900 Super Black, with an HB Body (European import) topcoat that I've had
some truly awesome results with every other time I've used it before. Its clarity and gloss is
incredible, and it also shoots to the best true "wet look" finish that's smooth, REALLY smooth,
without a trace of orange peel, that I've ever personally shot or seen. And it's not very expensive,
either. DuPont ChromaClear is a LOT more expensive and it's not any better.
I haven't yet decided if I'll keep the grille in its factory charcoal (in which case I'll use my brand new
grille, factory fresh from Toyota) or if I want to go full black on it. If I go black, do I want full gloss
black or do I want flat black or something else?
Decisions, decisions.
CJ
