change spark plug and wired set - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2008, 01:46 PM   #1 (permalink)
View zq_frank's Photo Gallery
HI:
I'd like to change the spark plug, my car is 1999 camry V6. the mileage is 220k km. Is that required to change the wire set with the spark plug? The current wire set is still the original one.
Thanks!
zq_frank is offline   Reply With Quote
Old 04-24-2008, 03:28 PM   #2 (permalink)
View toyomoho's Photo Gallery
I would just inspect them for damage, etc. You can do a ohm resistance check, no more the 25K ohms per cable. If the engine is distributorless it only has three cables.
Old 04-24-2008, 03:33 PM   #3 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
Opinions vary on this issue to be sure. With that mileage the wires owe you nothing and may be well toasted. Since the back plugs are a bitch, changing the wires at the same time may be a prudent decision.
FWIW
YMMV
DFBonnett is offline   Reply With Quote
Old 04-25-2008, 10:21 AM   #4 (permalink)
View nikita's Photo Gallery
That engine has coil-on-plug. There are no wires. You did state 1999 V-6, which is the same as mine.
nikita is offline   Reply With Quote
Old 04-25-2008, 10:50 AM   #5 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
The 99 v6's have 3 wires, the front three plugs are coil on plug, but the spark plug (High voltage) circuit is shared with the corresponding rear bank plug.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 04-25-2008, 05:26 PM   #6 (permalink)
View hassanbigboss's Photo Gallery
yeah I would go ahead that replace the wires if you want to spend the money on them........but if there is no problem with them than I would just leave them as is.........but yeah......the back plugs are a bitch to change........I changed them on my V6 and it took me about 45minutes to and hour to change the back ones while the front three only took like 5 minutes......again........its up to you......if you do the ohm test as suggested and the pass..........than let them be.........if not replace them with the spark plugs...good luck
hassanbigboss is offline   Reply With Quote
