Power window problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2008, 08:24 PM   #1 (permalink)
youngflashycamr's Avatar
View youngflashycamr's Photo Gallery
3rd Generation Power window problem
i just got done installing a new window motor in my driver side rear door..the motor works fine, but it doesnt go up. neither did the one before it. and the master window switch isn't helping either.. can someone help me?
i like having had lulz.
also, shares his name with the first civic i got laid in.
AIM: imeffindash
Originally Posted by Venom_5 View Post
everyone IS entitled to an opinion .... yours is just wrong
youngflashycamr is offline   Reply With Quote
Old 04-24-2008, 09:06 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I am guessing that you have already checked the motor function with separate power source and that it works and that you are not getting 12 VDC to both wires to the motor. That being the case, the most likely cause is a broken wire in the driver side door hinge wire loom. Use a multimeter between the plug to the master switch and the plug at the drive side panel (from the door hinge loom) and check resistance (should show near zero resistance for each wire). Wiggle the wires at the hinge each time just to be sure (if the needle fluctuates that's bad).
Luck,
Kep
