Help with oil leaks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2008, 12:12 PM   #1 (permalink)
View Cajun's Photo Gallery
4th Generation Help with oil leaks
I have a couple oil leaks on the old 98 4cyl beater. Trying to find out the most common place to look.
One is on the passenger side, probably the oil pump seal. The power steering pump is soaked with engine oil. The back of the timing cover and engine are also covered in an oily film.
The other is on the drivers side of the engine, around where the coil packs are below the intake. The back side of the motor has oil all over it. as well as the differential. There is a metal tube under the intake right by the coils, EGR maybe, and it is covered in oil. Is this the valve cover? Or maybe the cam seal?
I need to change the timing belt and water pump and was going to get a full kit that has everything, does this one look good to you guys?
http://cgi.ebay.com/ebaymotors/Timing-Belt-Kit-Toyota-Camry-1992-2001-4-Cyl-Complete_W0QQcmdZViewItemQQcategoryZ33625QQihZ025Q QitemZ380020924037QQrdZ1QQsspagenameZWDVW
Thanks.
2009 Prius
2007 Tacoma Double Cab - TRD sport - V6 - Auto
2007 FJ Cruiser - TRD Special Edition - 6 speed
2007 Camry Hybrid
1998 Camry 4cyl "Beater" 200K+ miles
Cajun is offline   Reply With Quote
Old 04-25-2008, 10:58 PM   #2 (permalink)
View chullen's Photo Gallery
Thanks.
Ok first you maybe be right about the oil pump seal however, a bad cam seal can cause oil to leak down the back of the timing cover. I would change the cam seals and oil pump seal. I would also change the valve cover gasket since it is probally very hard and cracked also. I would never buy a ebay water pump and timing belt as they in my opinion are of a lesser quality than toyota factory parts, but is up to u.
1999 Camry V6 5 spd- Daily Driver
2006 Civic Si 192 whp- SOLD
1986 Corolla GTS 250 whp- SOLD
1996 Accord EX- SOLD
Production Team Leader at Mercedes Benz
chullen is offline   Reply With Quote
Old 04-28-2008, 09:02 AM   #3 (permalink)
Anybody got a link to a how-to on Cam seals?
2009 Prius
2007 Camry Hybrid
Old 04-28-2008, 02:02 PM   #4 (permalink)
Tech In Training
View Gun5's Photo Gallery
usually you can just cut the lip or pry them out with something
BE CAREFUL NOT TO SCORE the cam though same goes with crankshaft... my girls camry we just picked up for the GF has the same issues I just ordered cam seal, crankshaft seal, oil pump seal, timing belt set, and both acc belts
2000 Camaro Z28 - Full Bolt ons, Heads/Cam
1994 Firebird Formula - Full Bolt ons, Heads/Cam *Parted Out*
Coming Soon 1995 Camry LE 165k
Gun5 is offline   Reply With Quote
