how do I reset my 97 camry alarm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2008, 11:41 PM   #1 (permalink)
View zava's Photo Gallery
I have a 97 camry le with fcc id elvat6b written on my keyless remote. there is a red button on dashboard related to alarm but not sure how it works.
my car wont start and I am sure it is about the alarm.I have searched the web but nothing worked so far.I think I need to reset my alarm but I don't know how to?
May someone please help me, how do I reset the alarm to start my car.
zava is offline   Reply With Quote
Old 04-26-2008, 02:54 PM   #2 (permalink)
View mkll/mx83's Photo Gallery
Not sure how to reset the alarm. I have the same system in my 97. The red button on the dash is for vale parking. Normal it is out and not lit.
Have you tried disconnecting the battery or pull the EFI fuse for a minute or so. This will reset all the electronics.
Good luck
R Bodiot
mkll/mx83 is offline   Reply With Quote
Old 04-27-2008, 12:28 PM   #3 (permalink)
Good luck
R Bodiot
yes, I have tried disconnecting batterr and EFI but no luck yet.when I insert the key turn the switch, alarm goes crazy, and car wont start.then I press the alarm button on dashboard (red) alarm shuts down but car still wont start.I have found different programming codes for diferrent models (avalon, 4 runner etc) but nothing for 97 camry and those did not work.
dealer tells me to tow it to them so that they can program.they have no mercy, towing would cost hundreds and not to mention programming.
anyone can help?
Old 04-27-2008, 01:07 PM   #4 (permalink)
E-mail me your e-mail address and I'll send you a copy of the programing instructions for this transmitter. My e-mail is: rbodiot@comcast.net
Thanks
R Bodiot
Old 04-29-2008, 10:04 AM   #5 (permalink)
Thanks
R Bodiot
drzavajung@gmail.com
thank you very much..
Old 04-18-2009, 01:42 PM   #6 (permalink)
View gtransformer's Photo Gallery
gtransformer@gmail.com
Please send me a copy. Thanks a lot!
gtransformer is offline   Reply With Quote
Old 04-18-2009, 11:25 PM   #7 (permalink)
View mspringer's Photo Gallery
Are you sure the battery is not dead?
If the battery is really low, when you turn the key, voltage drops, the alarm will come on.
Try jumpstarting as a test.
mspringer is offline   Reply With Quote
Old 12-26-2009, 07:38 AM   #8 (permalink)
View sbradley's Photo Gallery
Camry Alarm Reset
After disconnecting the battery, alarm wouldn't stop ringing and car wouldn't start even after trying to jump. AAA mechanic came and overrode alarm system by "lock driver door with key, unlock two times with key, put key in ignition and push the red alarm button. This should deactivate the alarm".
sbradley is offline   Reply With Quote
