Trailing arm question... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2008, 11:31 AM   #1 (permalink)
View jermag24's Photo Gallery
After trying to get a 4 wheel alignment, the shop told me the left rear trailing arm was bent (the one with the threaded adjustment on it), and the left front hub bearing had some play. This is probably from a hit and run that happened a few years ago. Does anyone know what the part number is for the left rear trailing arm? Anywhere else to get it besides the stealership? The ones I found online didn't have the threaded portion to adjust the alignment. Thanks!
jermag24 is offline   Reply With Quote
Old 04-26-2008, 11:48 AM   #2 (permalink)
View toyomoho's Photo Gallery
Dealer only part, if going Toyota OEM check out discount Toyota dealers such as the one below:
http://www.trademotion.com/partlocat...?siteid=214074
Also try auto junk yards.
Old 04-26-2008, 01:00 PM   #3 (permalink)
Found it on autopartsplace.com
P/N: 48740-33060
