THUD over bumpers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2008, 08:54 PM   #1 (permalink)
View m52go's Photo Gallery
4th Generation THUD over bumpers
hi - for a while now, when my car goes over even average-size bumpers, at crawling-slow speeds sometimes, i'll hear a resounding THUD coming from the undercarriage of the car (its completely stock right now). we asked a mechanic at the dealer about it and he said everything under there was fine.
now that i'm actually going to mod it a little, one of my goals is get new springs and struts, which will lower it slightly.
my question is ... do any of you know what could be causing this sound ? i really don't think its ordinary, and im not sure lowering will help
m52go is offline   Reply With Quote
Old 04-26-2008, 11:34 PM   #2 (permalink)
Cannabis Camry's Avatar
View Cannabis Camry's Photo Gallery
Check the end links of the front stabilizer bar. I recently bought a 98 Camry and somebody had replaced one of the end links with one that was too long. Make sure the bottom of the endlinks are not in contact with the lower control arm. That would be causing a thud.
Also, Push down on all the corners of your car when it is parked and see if you can hear which wheel the thud is coming from. If it does it over small bumps at low speed then it should do it from you pushing down on the car.
Cannabis Camry is offline   Reply With Quote
Old 04-27-2008, 11:23 AM   #3 (permalink)
thanks dude ... i'll give that a try
Old 04-27-2008, 11:40 AM   #4 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Strut mounts. Ive got to replace all 8 of mine.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 04-27-2008, 01:53 PM   #5 (permalink)
Tech In Training
View Gun5's Photo Gallery
got the same thing in the back of a camry i just picked up... also one of the stabilzer bars up front aint even hooked up... they will make loud thuds when out so check them for play
2000 Camaro Z28 - Full Bolt ons, Heads/Cam
1994 Firebird Formula - Full Bolt ons, Heads/Cam *Parted Out*
Coming Soon 1995 Camry LE 165k
Gun5 is offline   Reply With Quote
