oil on spark plug - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2008, 08:56 PM   #1 (permalink)
tekno9000's Avatar
View tekno9000's Photo Gallery
USA oil on spark plug
While changing the spark plugs, I noticed oil on the spark plug. The oil was so much that my i saw black smudges on the top head (other end of sparking end). This plug is the first one from the distributor cap side. Help me to prevent this.
1995 Toyota Camry 5SFE 130,000 miles.
Thanks,
Tekno 9000
1995 Camry LE 5SFE 4 Cyl.
tekno9000 is offline   Reply With Quote
Old 04-27-2008, 12:16 PM   #2 (permalink)
Woo Hoo!!
sbushnak's Avatar
Gameroom cash: $173010
View sbushnak's Photo Gallery
Could be the spark plug tube seals. Change them along with the valve cover gasket.
1997 Toyota Camry LE I4
@ 193,000 miles
sbushnak is offline   Reply With Quote
Old 04-27-2008, 03:35 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Maybe before you buy new gaskets go and get a 30mm socket and check that the torque on the tube nuts is 17 ft lbs (don't over torque). You may be able to snug them up and solve the problem. If not, the next step would be what sbushnak suggested.
Kep
Old 06-24-2009, 09:05 PM   #4 (permalink)
tekno9000's Avatar
I bought a torque wrench. Where are the tube nuts?
Thanks,
Tekno 9000
Old 06-24-2009, 09:53 PM   #5 (permalink)
View KevinACrider's Photo Gallery
I wouldn't even bother with that. Just replace the gaskets, chances are they are worn down even if the torque is a few pounds off.
KevinACrider is offline   Reply With Quote
Old 06-24-2009, 10:23 PM   #6 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
+1.
I had the same problem as you; cylinder 4 has a huge amount of oil on the plug. I'd say the thread sealant(liquid gasket) at the bottom of the (spark plug) tube no longer seals properly than the top tube seals. Here's a good write-up:
'Spark plug tube leak' fix
It's near the bottom and was done on a 5S.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
