Intake Air Control Valve Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2008, 08:57 PM   #1 (permalink)
View Rob_0126's Photo Gallery
I have a 92 Camry V6. I took out the Intake Air Control Valve and cleaned it up, it was really cruddy.
I had to use the original gasket because NAPA doesnt carry them nor many other single gaskets, much less the part itself.
Question is, could I buy a cork gasket material and make my own?
If not, what do you suggest?
Seems to be smoother but Im not sure if it's a tight seal because of the old gasket. Whoever put the last one on tightened the bolts way down, when it's only 10 ft/lbs. So I think the gasket might be quite squished.
What would it do if their is no tight seal? Symptoms?
Also, would cleaning the TPS and IAC with deep creep be ok? Can I use the original gaskets because NAPA didnt have them? Would using RTV be abad Idea?
thanks much.
Robert
Rob_0126 is offline   Reply With Quote
Old 04-26-2008, 10:10 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
just reuse the gasket and put a small film of rtv on it to seal it up
HaHa
Old 04-26-2008, 11:52 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Most RTVs are O2 sensor safe but it never hurts to verify it by reading the label for "O2 Sensor Safe".
Kep
Old 04-27-2008, 12:57 AM   #4 (permalink)
Immah goto teh store and get some tomorrow then. I want to make sure it's sealed. Then clean the TPS and IAC.
Any suggestions on them?
Robert
