Overheating Issues
Mom's had this car for a while (95 LE, 5FSE), I recently did a tune up on it. It consisted of:
New plugs, wires, cap and rotor.
New coolant temp sensor, oxygen sensor, PCV valve and gasket (those things get so brittle)
I replaced her radiator & cap a while back due to the top portion cracking. Recently, the lower half of the rad cracked open somehow and the car overheated. I replaced the radiator, thermostat & gasket, and filled it with 60/40 Water/Zerex G-05.
HERE IS THE PROBLEM:
When I heat up the car, everything is fine. Upper & lower hoses are hot.
After the car has been driven for a bit, the overflow tube starts shooting bubbles into the overflow tank. Eventually the coolant is so offset by the bubbles that a bit overflows out of the tank. When the car cools again, the coolant is sucked back into the radiator like normal.
At first I thought it was a headgasket, but there seems to be no coolant in the oil, and no oil in the coolant. A compression test yielded ~200 psi on all the cylinders (a tad high). I am seeing some milky light brown goo underneath the oil cap, but I'm thinking that's from the massive sludge in the engine.
WHAT is going on?! I'm super confused.
