Questions about KYB mounts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-28-2008, 04:25 PM   #1 (permalink)
View arcosmo's Photo Gallery
4th Generation Questions about KYB mounts
After reading through literally dozens of threads over the past few weeks on strut changes, I just need to clarify a few thing before I pull the trigger on struts/mounts & boots for my wife's (soon to be my daughter's) 99 4 cyl auto Camry.
This will be my daughter's first car (will be 17 in Oct) and I am getting it ready for her to be able to drive it for at least a few years. It has the original OE struts/mounts and boots with 178,656 miles on them. I decided on KYB GR-2 struts all around since I won't be lowering the car (re-using OE springs). Here are my questions:
1. Are the new Toyota mounts better or worse than new KYB's?
2. If I go with the new KYB mounts, do they come with new bumpstops and boots?
3. IIRC the new KYB mounts come with new bearings. Is this correct?
4. IIRC the Toyota mounts DO NOT come with new bearings, bumpstops or boots. Is this correct?
5. Do the new KYB or Toyota struts come with new springseat insulators?
6. Have I forgotten any other items?
7. I have done an eBay and Google search on pricing but would appreciate if anyone knows where I can get them for less?
Thanks a ton for the help!
Mike
97 Mazda Miata Classic Red #99ES 202K+
99 Camry LE 5S-FE Auto Champaign Beige 202K+
arcosmo is offline   Reply With Quote
Old 04-28-2008, 05:26 PM   #2 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
Originally Posted by arcosmo View Post
After reading through literally dozens of threads over the past few weeks on strut changes, I just need to clarify a few thing before I pull the trigger on struts/mounts & boots for my wife's (soon to be my daughter's 99 4 cyl auto Camry.
1. KYB is like or better than factory replacement.
2. If your strut boots are still good (which I doubt) you will need to get those extra. It is not included.
3. I believe your Camry has a bearing so, if the spring seat and bearings are worn out, you will need these also. Again you have to buy these separate.
4. They do NOT come with it.
5. They do NOT come with it.
6. When you replace all the struts you might need to consider new end links because the end links need to be removed when replacing the struts, so it would be a good time to replace also with the high mileage on your car, yor end links are more likely dead.
7. Check out this website http://www.importrp.com make sure to simplify the of choice of vehicle to get the proper price.
Here is the PDF file to check what you need for your 99 Camry 4CYL
http://www.kyb.com/catalog/2008_passenger_car.pdf
Good luck
cruisn76 is offline   Reply With Quote
Old 04-28-2008, 05:59 PM   #3 (permalink)
View toyomoho's Photo Gallery
Just replaced the stock mounts in a Gen 3 with KYB.
Can’t say for new Toyota mounts but the old mounts had better workmanship then KYB. These mounts only came with the bearing, nothing more. Don’t know if Toyota mounts come with the bearing, suggest talking to their parts department where you will order the part.
Not sure of the other questions, others will no doubt post.
For Toyota OEM parts various TN members have suggested the websites below.
http://www.trademotion.com/partlocat...?siteid=214074
http://www.performancecenter.com/
http://www.discounttoyotaparts.com/
http://www.toyotapartsales.com/
http://www.trdparts4u.com/
http://www.toyotaoemparts.com/
For none OEM parts one site have used with very good result is www.rockauto.com. Watch on shipping as they drop ship from numerous locations, as such shipping costs can add up.
Some sites offer free shipping over $50.
If you have not done shocks before you will need a spring compressor.
Old 04-28-2008, 08:04 PM   #4 (permalink)
Don't get mad. Get even.
El Tano's Avatar
View El Tano's Photo Gallery
I just got my whole suspension for my 98 camry at coolparts.com, there is a coupon on the sellers forum for a discount..
Now I'm short on time, but I'll come back to this thread latter or tomorrow and give you all the info that you need but you have most of the info that you need on the answers above..
just for now KYB high mount's craftsmanship are shit, they look like refurbished parts.
Everything else it's good.
I have to go..
El Tano is offline   Reply With Quote
Old 04-28-2008, 10:45 PM   #5 (permalink)
Thanks for the replies! I almost forgot the end links. Keep em comming everyone. As soon as I get all the parts I will be posting website URLs and part #s to make it easier for future searches.
Mike
Old 04-28-2008, 10:52 PM   #6 (permalink)
cruisn76's Avatar
I have to go..
KYB High Mounts??? Are they the same as Strut Mounts???
Old 04-29-2008, 12:15 AM   #7 (permalink)
El Tano's Avatar
Yea, I was in a hurry and I wrote that, sorry... Struts mounts, I don't know about the quality but the finish on the item it's very bad and it makes it look like it's a refurbished part, the metal it's very uneven and they painted it with a spray can of black paint, I called KYB and talked to customer service about this and the guy told me that he was going to look into it, but I don't believe he will. Everything else it's fine, the struts are made in japan, the lowwer spring insulators good, the rear strut mounts good, the boot kit are made out of plastic the they come with the stop.
Here are the parts for the 98 camry just in case you need them:
Strut mount SM5179 FRONT RIGHT Suspension Strut Mounting Kit
Strut mount SM5180 FRONT LEFT Suspension Strut Mounting Kit
Strut mount SM5175 REAR Suspension Strut Mounting Kit
Strut mount SM5469 REAR Lower Coil Spring Insulator
Strut mount SM5441 FRONT LOWER Lower Coil Spring Insulator
Shock/Strut boot SB101 FRONT LEFT
Shock/Strut boot SB101 FRONT RIGHT
GR2 series 334245 FRONT RIGHT
GR2 series 334246 FRONT LEFT
GR2 series 334134 REAR LEFT
GR2 series 334133 REAR RIGHT
www.coolparts.com
The code is TNSAVE5. Please be sure to use all capitals because it is case sensitive.
This will take 5% off the order before shipping
Old 04-29-2008, 11:03 AM   #8 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
1. Toyota mounts are WAY better than KYBs in terms of quality, you get what you pay for. KYB mounts are good enough though.
2. No, you only get the mounts, bumpstop and boots must be purchased separately as with the Toyota ones.
3. Yes, you get new bearings with the KYB front mounts, the quality of those are worse than Toyota bearings also, but will still do.
4. Toyota mounts don't come with the bearings. No boot or bumpstop also like the KYBs.
5. Both don't come with the spring seat insulators. However, the Toyota boots have the upper spring insulator built on, KYB boots dont, its just a boot you slide over the piston.
WhiteRabbit is offline   Reply With Quote
Old 04-29-2008, 10:51 PM   #9 (permalink)
Thanks again everyone. Based on a few more hours of reading from hundreds of posts, I have decided to go back with OE Toyota Mounts. I will however still be ordering the KYB GR-2's though. When I receive everything, I will post the individual part #s for the OE Toyota mounts, bump stops, bearings, boots...etc so others looking for the information will have it here in one thread. If anyone already has the part #s, please feel free to post them.
Mike
Old 04-30-2008, 05:51 PM   #10 (permalink)
View TMetalMan's Photo Gallery
Great, I'd love to see those part numbers. Within the next couple months I'll be redoing all of my struts/springs/etc.
TMetalMan is offline   Reply With Quote
Old 04-30-2008, 05:57 PM   #11 (permalink)
Just got an email quote from Toyota of Dallas on the factory Toyota mounts, bearings, boots, bump stops & lower spring perch insolators, $396.92 + shipping.
Here are the part #s and pricing break down minus shipping (it will be higher or lower depending on your location).
48750-33020 Support A $87.08 X 1 (Mount RR)
48760-33020 Support A $87.08 X 1 (Mount LR)
48603-33021 Bumper S $55.63 X 1 (Mount RF)
48609-33121 Bumper S $55.63 X 1 (Mount LF)
90080-38148 Collar $4.81 X 2 (Bearing)
48341-32053 Bumper, R $8.08 X 2 (Bumpstop R)
48331-06011 Bumper, F $7.78 X 2 (Bumpstop F)
48258-0E010 Insulator $8.35 X 2 (Insulator, Spring Perch R)
48158-33020 Insulator $12.68 X 2 (Insulator, Spring Perch F)
48157-07010 Insulator $14.05 X 2 (Dust Boot, F)
Admittedly, I wasn't expecting the cost to be this high for some routine wear items on a high volume car. I put Koni Sport Adjustable shocks on my Miata for $750 installed which including new bumpstops, boots, shipping and custom 4 wheel alignment. This Camry is going to run $1100 installed including ALL of the above parts with alignment and these struts arent even remotely comparable to the Koni shocks!
Mike
Old 04-30-2008, 06:38 PM   #12 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
That's about right on the parts. I just did the suspension on my '95 and the total for all the strut mounts, boots, bump stops, etc. from Toyota was $462 with tax. I didn't pay shipping cause I got them locally.
I bought Tokico struts for $327 on eBay and H&R Sport springs for $247 from Tire Rack. I also did the TRD RSB at the same time with new endlinks and Gen4 bushing brackets which added another $305 in parts.
You're reusing your old springs, so no cost there.
My parts cost just with struts and associated replacement parts would have been $789
Add in the H&Rs and my parts total goes to $1036.
Add in the RSB and my total suspension parts bill was $1341. It adds up fast.
eddie926 is offline   Reply With Quote
Old 04-30-2008, 11:29 PM   #13 (permalink)
cruisn76's Avatar
Thats sounds about right, my 92 is maybe 200-300 less, since I got a better price on a RSB, strut mounts/boots, and end links.
But I am sure your car runs really smooth after that maintenance.
My car is going under the wrench late this week. So I should have a better than factory ride when it is all said and done!
Old 04-30-2008, 11:41 PM   #14 (permalink)
View TOYTECH25's Photo Gallery
my choice is OEM
1. Are the new Toyota mounts better or worse than new KYB's? KYB'S ARE GOOD BUT TOYOTA KNEW WHAT THEY WARE DOING WHEN THEY BUILD THE OEM MOUNTS
2. If I go with the new KYB mounts, do they come with new bumpstops and boots? DUST BOOTS, DO NOT COME WITH IT SOLD SEPERATLY
IF THE BEARING DONT MAKE NOISE WHEN TURNING OR GOING OVER BUMPS THEY ARE OK NO NEED TO REPLACE THEY DO NOT COME WITH A KIT TOYOTA WOULD MOST LIKELY BE THE ONLY PLACE YOU FIND THEM THEY RUN FOR ABOUT 80 BUCK
4. IIRC the Toyota mounts DO NOT come with new bearings, bumpstops or boots. Is this correct? STRUTS, SPRINGS, BUMP STOPS, BOOTS, BEARINGS, NO SUCH A THING AS A KIT ALL SOLD ON THEIR OWN
ONCE AGAIN SOLD SEPERATLY IF YOU NEED TO INSULATE THE SPRING TO PREVENT SQUEEK NOISES AND CANT FIND NEW ONES USE THE OLD ONES AND PUT SHRINK TUBE AROUND THE LOWER AND UPPER COIL I JUST GAVE YOU MY TRICK IT WORKS I USE IT IN THE SHOP ALL THE TIME
YOUR ON THE RIGHT TRACK TAKE MY WORD IF YOU CAN AFFORT IT BUY OEM YOU WILL NOT REGREAT IT I USE AFTERMARKET PARTS WHEN I LOWER THE CARS OR OEM PARTS ARE NO LONGER AVAILABLE
TOYTECH25 is offline   Reply With Quote
Old 05-01-2008, 12:40 AM   #15 (permalink)
View Kitto's Photo Gallery
they have free shipping on order over $200
Kitto is offline   Reply With Quote
