99 Camry Clunking, Banging And Rattling - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-28-2008, 09:17 PM   #1 (permalink)
View vultrix's Photo Gallery
Canada 99 Camry Clunking, Banging And Rattling
Hello folks, I have 99 Camry with about 225'000 KM's and getting alot of noise from rear mostly rattling and clunking, but I have had sway bar bushing replaced with original toyota parts a year ago and also sway bar links replaced but with a cheap pair from EBAY a year ago. I just had tires changed and I pulled on the links in rear and they move a little not to bad but probably needs replacing. Also when on the highway going over 100 KM, whenever I turn to the left slightly the car sways back and forth ( maybe front are gone too but no movement in those) But I get alot of rattling and clunking noise from rear which maybe part links but I also have had struts replaced 2 month ago as wellin rear with monroe sensastrut but the noise seemed to be there before that...I didn't change strut spring or mount... Is it possible for this to be more than bad sway bar links. Any ideas on what to look for or try??? By the way, I find the monroe strut not so great especially in cold weather!!!
vultrix is offline   Reply With Quote
Old 05-05-2008, 02:14 PM   #2 (permalink)
View joede's Photo Gallery
I had the same problems with my 99 Camry a while back. I often could nat tell if noise was coming from front or back.
There is a TSB out covering the noise from the fronT: SU001-00. It shows the part numbers for new suspension supports (the part that goes on top of strut and holds it to the car).
I also replaced the stabalizer bushings p/n 48818-06090.
These two changes too care of all the clinking. Did you peplace the right stabalizer bushings i.e. P/N 48818-06090? Hope this helps.
joede is offline   Reply With Quote
