01 camry, Draw kills battery in 1 hour
I have a 01 Camry CE. Once a while the battery is dead and now I found out it drain completely in 1 hour. I found out that it was from the braking system. I went to the brake switch and found out the draw is from the green/white wire. That wire goes to the lamp failing module in the trunk. I did some reading here and it says that the white/black wire to the module is ground. When the module is unplugged, there is no more draw. When I test all the wire that goes to the module, green green/red and green/orange are all 3 grounded. Is that normal? Since they are grounded, thru the module they ground the green/white that goes to the brake pedal switch. I read that none of the wire beside the white/black should be grounded.(it was for a different year) Any help would be appreciate.
