Make sure the distributor rotor is turning OK. The wires between the distributor, igniter, ECU, etc are OK.
Resistance between the + and - coil terminals should be 0.36-0.55 ohm cold. Between the + terminal and high tension terminal 9.0-15.4K ohms cold.
Remove the high tension wire from the distributor, hold near a chassis ground then crank engine and check for spark.
The coil + terminal should have 12V when ign switch on. Make sure the - ground is OK.
Check the plug wires resistance, should be a max of 25K ohm.
Check distributor pickup coils. G1-G 125-200 ohm, G2-G same, NE-G 155-200 ohm cold. G = ground, The terminal order is G, G2, G1, NE left to right when looking down at the cap.
