quick question about tire size - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2008, 10:34 PM   #1 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426253
View EEngineer's Photo Gallery
ok, I REALLY want a set of the SILVER SUBARU STi rims
they are made either by Enkei or BBS I believe, but they look the same i think
the rims are 17x8
now, My tires are 215/45ZR/17
the specs online said they will fit anything that's between 7-8 inches wide.
the stock tires for the rims are 225 though
so would it make a huge diff between 215 and 225?
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 05-02-2008, 10:35 AM   #2 (permalink)
Born to Drive
EEngineer's Avatar
anyone?
Rest in Peace
Old 05-02-2008, 12:24 PM   #3 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
Is the lug spacing correct for a Camry?
Or do you mean that you want that style of rims for your camry?
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 05-02-2008, 12:30 PM   #4 (permalink)
Born to Drive
EEngineer's Avatar
Yea man, all the subaru impreza WRX STi wheels of that style is 5x114.3
they are 17x8....and their tires are 225/45/17 i think....i'm just thinking if 215/45/17 will do or not
Rest in Peace
Old 05-02-2008, 02:00 PM   #5 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
If your stock tire is a 195/70/14 then the 215/45/17 is the most commonly recommended size for you to plus size with.
The 215 will not be a problem on that wheel.
Have you checked to see what the offset is on that wheel? In addition to correct lug pattern and tire size, you need the right offset as well. If you stated the offset, I missed it. You also need to know the center bore size since it's a factory wheel instead of an aftermarket wheel. I don't know what the hub size is on Subarus. Factory wheels are made to fit the hub of the specific car they're going on whereas aftermarket wheels are made with larger center bore so that they can be fitted on many cars. If the center bore is the same or bigger as the Camry that's fine. If it's smaller you won't be able to use them.
eddie926 is offline   Reply With Quote
