Another CAmRY... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-03-2008, 10:24 AM   #1 (permalink)
View Technique07's Photo Gallery
4th Generation Another CAmRY...
Hey i just got a white 97 camry xle (4 cylinder) with 60k miles. thing is in mint conditon!.except for one thing...
the sunfoor leaks slow drops when it poors right on the drivers side corner. IS it easy to fix ???
and do you guys have any suggestions on suspension upgrades. i want to ride to be smoother. wat products are out their that can help me?
thankSSS
[SIGPIC][SIGPIC][SIGPIC]teeeheee
Technique07 is offline   Reply With Quote
Old 05-03-2008, 11:09 AM   #2 (permalink)
View camry314's Photo Gallery
sounds like you would need to drop the headliner and check the drain tubes. Maybe one feel off and its causing the leak. Start there.
camry314 is offline   Reply With Quote
Old 05-03-2008, 02:18 PM   #3 (permalink)
'_'
Touge Star
'_''s Avatar
Gameroom cash: $421512
iTrader Score: 10 reviews
View '_''s Photo Gallery
What suspension setup do you have now?
山道だいすきです。
http://www.cardomain.com/ride/2538603
'_' is online now   Reply With Quote
Old 05-03-2008, 09:25 PM   #4 (permalink)
4th Generation
i have the stock setup? idk
Old 05-03-2008, 11:51 PM   #5 (permalink)
[g4.Rep]
Gameroom cash: $245932
View ONE_to_HATE's Photo Gallery
welcome and post pics. This is pretty much useless w/out 'em!
http://i55.tinypic.com/oa6dj8.jpg
[TRD.jpn][TRD.usa][5Zigen][DDM][DENSO][BC][STICH][FEDERAL][STANCED]
ONE_to_HATE is offline   Reply With Quote
Old 05-04-2008, 11:01 AM   #6 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
ONE_to_HATE I like your sig man thats pretty tight!!
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 05-05-2008, 09:34 AM   #7 (permalink)
'97 Camry V6 XLE
View thegmann's Photo Gallery
Definably check the drain tubes. When the drain tubes in my 97 xle clogged water poured down inside of the plastic front pillar cover on my passenger side and ended up in the floor mat.
Moral of the story: The sun roof doesn't have a perfect seal and without the drain tubes working it will leak.
thegmann is offline   Reply With Quote
Old 05-05-2008, 11:56 AM   #8 (permalink)
4th Generation
how do you get to the drain tubes?
Old 05-05-2008, 12:25 PM   #9 (permalink)
'97 Camry V6 XLE
This thread has the details on how to remove the headliner. http://www.toyotanation.com/forum/ar...p/t-98100.html
You only need to remove the things that hold the front of the headliner in place. You should be able to reach the tubes. You might also have to remove the A pillar plastic covers if I remember correctly though.
The drain tubes are clear plastic tubes.
