What is this? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-03-2008, 07:02 PM   #1 (permalink)
shajbot's Avatar
View shajbot's Photo Gallery
What is this?
Planning on putting a cone air on the stock air pipe. Upon removing the air box I notice the ???? component in the pic leaves only a small hole about 5/6 of an inch in diameter of the original pipe. The thing has wires into it.
My questions are what is that? Do I need it? How about the resonator? How do I need to patch the pipe up upon removing the resonator?
This is on a v6 1mzfe.
shajbot is offline   Reply With Quote
Old 05-03-2008, 07:15 PM   #2 (permalink)
View camlex's Photo Gallery
I think that is MAF Sensor..
camlex is offline   Reply With Quote
Old 05-03-2008, 07:35 PM   #3 (permalink)
shajbot's Avatar
http://www.autoshop101.com/forms/h34.pdf
That document states the MAF is for the ECM to calculate engine load, ignition and what not. So I guess it's critical...? Aftermarket pipe doesn't need this thing so...
Old 05-03-2008, 07:48 PM   #4 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
^^ wrong
you need that. just about every aftermarket manufacturer of intakes will have the pipe come with a section cut out just so that it fits the MAF sensor.
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 05-03-2008, 07:51 PM   #5 (permalink)
I work on euros.
View 96CamrySport's Photo Gallery
ha! that's your Mass Air Flow sensor or MAF. Yes, it's important, if you unplug it the engine has to revert to speed density mode and will throw a check engine light. That is the primary sensor for dictating your fuel metering. Throw it away and your car will barely drive.
As for the resonator, it's not necessary, and most afm pipes delete them, but I hear they do help with low-end torque. They also quiet the intake down. I blocked mine off by taking the resonator into home depot, finding a rubber cap that fit over it, then hacking the neck off and clamping it back in place with the cap clamped over the end. I'm sure there are much cleaner ways, but it worked.
1996 Camry Sport (that's a DX Coupe with decals) with 186k
european cars are just like japanese cars, just heavier and more expensive.
7 ASE's.
96CamrySport is offline   Reply With Quote
Old 05-03-2008, 07:57 PM   #6 (permalink)
shajbot's Avatar
Thanks a lot guys. I is clear of this.
Old 05-03-2008, 07:58 PM   #7 (permalink)
shajbot's Avatar
Originally Posted by 95WhiteCamry View Post
^^ wrong
No wonder why the pipe is so expensive.
