Something is dreadfully wrong (2000 Camry) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2008, 12:45 PM   #1 (permalink)
View jwright109's Photo Gallery
4th Generation Something is dreadfully wrong (2000 Camry)
Over the past year my 2000 camry has been having what seemed like minor electrical problems due to a bad alternator, or so i thought. but, after going to the local auto zone and getting a test run on the battery and alternator, i found that both were in tip top shape.
so here is the scoop
1.Whenever I am driving and hit the brake my radio shuts off for a few seconds and then comes back to normal.
2. Whenever I am driving with cruise controll and i use the brake the cruise controll shuts off.
3.Whenever I turn on my high beams at night not only does cruise controll shut down, but the little orange ABS light comes on and my radio flashes non stop. I then have to put my car in neutral untill the ABS light goes off and then put the car back into drive before i can use the radio or cruise controll again.
4. When i roll my windows up at night, the headlights dim significantly
any help would be much appriciated!
thanks.
jwright109 is offline   Reply With Quote
Old 05-04-2008, 01:59 PM   #2 (permalink)
View J_Phu's Photo Gallery
Maybe you have a bad connection on the battery or the alternator. check your grounds see if they're good. Make sure all your connections are clean too
J_Phu is offline   Reply With Quote
Old 05-04-2008, 08:32 PM   #3 (permalink)
View putz82's Photo Gallery
I would check your connections and look under the dash and make sure there isn't anything obvious i.e. somebody wired something and didn't do it right.
Your cruise control is supposed to turn off when you hit the brakes though.
putz82 is offline   Reply With Quote
Old 05-08-2008, 08:48 AM   #4 (permalink)
View Albetime's Photo Gallery
I have a similar problem but just a few times!
When I turned on my headlights the radio would shut off and only once the ABS light came on. I did look at the battery terminals and they do need a good cleaning but I have yet to take care of this problem. So far it hasnt reoccured but I will clean the battery terminals. Let me know what you find out!
Albetime is offline   Reply With Quote
Old 05-08-2008, 09:51 AM   #5 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
Is it a stock or aftermarket radio? Regardless, make sure someone didn't try to 'hard wire' it to the main harness, perhaps they tapped into something they shouldn't have...
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 05-08-2008, 02:05 PM   #6 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
+1 on J_Phu. If they're obviously loose and/or dirty clean and tighten and see if that solves it. If not, take it in to an Auto Zone and ask them to check your battery and alternator to make sure that they are operating efficiently. If none of the above, write back.
Kep
Old 05-09-2008, 12:06 AM   #7 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Do you have any of the following:
1: Aftermarket Alarm
2: Aftermarket Radio
3: Remote Start
4: Aftermarket anything
5 Lug Corolla WHAT?
